Old 19-05-2008, 07:45 PM   #1
floater05
Default coolant leaking into cabin, 83 meteor
in my dads 83 meteor, theres a fair wack of coolant leaking into the cabin from sumwhere up under the dash.
anyone herd of this before? and what steps should we take to fixing this problem?
cheers floater?
floater05 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2008, 08:36 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Under your dash you have a mini radiator that is used to heat the cabin from the coolant in the engine. The coolant will be leaking from that or one of the hoses connecting it all through the fire wall.
The cheap 'fix' is to totally disconnect it, and just loop the hoses within the engine bay so the heater is totally bypassed (no more heater) or loop the pipe, see what is the problem (may just be the hose is shot - cheap fix) and then connect it all up again.
Had the same issue with my 76 Datto.
Old 20-05-2008, 11:23 AM   #3
dirty hands
Over Thinker
dirty hands's Avatar
or buy a heater core from a wrecker and try to fit it yourself
or have a radiator repair shop fit the replacement heater for you
i think the dash has to come out
but shop around for a good price
and make sure you get a quote in writting before they start
My car goes Brumm Brumm
