25-05-2008, 02:30 PM | #1 | ||
I took out my cluster (series 1 au fairmont ghia) to take the orange of my needles so they would be white for when i change to blue globes now i put the tacho and speedo needles back on but on turning the ignition on and turning the ignition of the needles shake and vibrate back and forth they both work fine and show tacho status and speed but the vibrating is annoying any help?
25-05-2008, 02:40 PM | #2 | ||
maybe they're cold...? lol just kidding, the best thing to do when putting them back on is, plug the cluster in and turn the ignition on, then put the needles back on, that should stop any issues with them as they are set at zero then
25-05-2008, 02:43 PM | #3 | ||
ill change this to be more specific i stuffed round with tacho needle doesnt do it no more the speedo needle still does when i turn igntion from 1 to 2 there are 3 constant beeps over and over for a bit then they stop
25-05-2008, 03:22 PM | #4 | ||
Ah k the 3 beeps was distance to empty indictator lol new cars speedo needle still vibrates tho any ideas?
25-05-2008, 06:54 PM | #5 | ||
ok ppl new problem my odometer wont light up now the dash is fully plugged in have i shorted something?
25-05-2008, 07:45 PM | #6 | ||
the globes may have died when the dash was removed. take it back out again and check them, that's all you can do
25-05-2008, 08:19 PM | #7 | ||
Thanks mate ill check em tomoz in day light ill also grab some replacements from a wreckers just in case
26-05-2008, 02:10 PM | #8 | ||
Tickford Equiped
how did you remove the orange off them??? Do they light up well now?
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
26-05-2008, 03:59 PM | #9 | ||
I used fine sandpaper that got it off i tried a knife to peel it but that was taking forever just becafeful u dont sand out clear ontop of the needles otherwise they go a frosty colour and yeh looks good i can even see them druing the day wearing sunnies now lol
