hey guys
I was reading the B series forum and people are having issues with shuddering from Bendix GCT pads and DBA slotted (mostly DBA 4000 series slotteds) apparently there is an issue with the pads leaving resin deposits on the rotor causing the shudder etc... are others having similar issues on AUs?? my other question is... what pads are reccomended for use with 4000 series rotors that arnt gonna chew my wallet OR my rotors to shreds i currently have Bendix Advance pads(presuming they are similar to GCTs as they were superseded by them) thanks guys
Smile
I put some new bendix brakes a few weeks back and found the car would not stop properly. I stuck some ferodo excels in there and she now even stops. I dont like bendix.Bendix cant stop my wagon safely.Second time its happened.Gave em benefit of the doubt and tried them the second time to have them ripped and thrown in the middle of my garage flooor pos brakes.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
not here much anymore
GCT's are the next step up from Advance, Advance are just brake pads while GCTs are apparently made to last a bit longer etc. I have Advance on my ute but theyre not up to scratch - theyre not a good enough pad for the way I drive (or should that be stop).
Cant comment on DBA's as I've never used them - always had RDA rotors because they are a cheaper product and do the same job. That, and for the 320mm brakes, a DBA rotor is about $400 - each.
2024 F150 XLT
#4 | |||
Back to Le Frenchy
What I can't understand is why on earth anyone would fork out for a great rotor like the 4000 and then just use a cheap pad on it. I am using DBA street slotted on mine atm (they're what came with the calipers and were pretty new) but I use Ultimates even with them.
Barra Turbo > V8
I only recently put DBA 4000's (Premium) on my TE and GCT pads and have had no hassles what so ever. Also they produce next to NO brake dust aswell.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
I had the DBA slotted (standard series) with GCT's, got shuddering after no time, by 4000odd km's they were screwed, had the rotors machined and a new set of GCT's on and had the issue come back within 2000km, I rang DBA and they said its due to the GCT being manufactured in layers or something along those lines and leaving a build up on the rotors.
Both are gone now, bought some cheap rotors and ferrodo pads and all has been good for the past 5000odd km's |
russell im unsure what your refering to as forking out for the 4000 series rotor then getting cheap pads??? unless your talking the ferodo rubbish.. but then the excel ? ferodos are still $100 for a set...
and the Bendix pads arnt Coretech or Ferodo Zero rubbish... or any of the other cheap and nasty supercheap crapola and i cant justify putting Bendix Ultimates on the car as they chew thru rotors which i believe makes them a bad match for that particular rotor combo for a street car??? unless other people have reccomendations for a decent street daily driver brake pad...??
#8 | ||||
Back to Le Frenchy
Critical Thinker
I dont recommend Bendix Advance pads or similar at all.
I had them on my EBXR8 years back. They caused hot sopts on the rotors and the whole pad and rotor setup had to be chucked. I ended up getting ultimates and a set of Protex rotors fitted and had no problems. This of course is dependant on your driving style. My style back then was probably regarded as more spirited.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
I got DBA5000 series to replace the 329mm premium rotors on my pursuit and Bendix are absolute garbage in the respect that you mention but when I replaced my brakes that was all they had at the time and you can be damn sure the cheap (not price wise) nasty rubbish wont be going on next time even if the car has to be off the road waiting for a special order.
Can't beat a Windsor for sound and low down torque. Liquid Silver Pursuit250 Custom gear and diff ratios ECU Exhaust Crow Comp. Valve springs Adjust. Rollers Cold air |
I have seen so many problems from the DBA rotors ... so i decided to go with RDA slotted rotors. They ahve been excellent ... and I use Bendix GCT pads as well.
Front rotors lasted me 60,000km along with pads ... and that's driving Sydney stop-start traffic with decent loads in the back ... they pulled up great the entire time ... only reason to replace them was they were low ... still pulled up well with no dust or noise. I just replaced the rear pads now ... they were low ... the rotors are still great on the rear ... so i left them as is. The good thing about RDA is they are cheaper than the DBA stuff as well. I have been really happy impressed with this setup.
#12 | ||
im trying to get away from a dusty pad...which the Advance on my car now are very minimal in dust compared to the ferodo crap i had on it when i got it...
so what do we reccomend guys??
I have the DBA 4000 rotors on my eb gt but not sure what pads. Got Ford to fit the rotors and they supplied the pads and the service guy said they fitted XR8 pads. Does anyone know what pads that would mean I have?
Thanks
____________ *** For Sale *** Red Flame Auto Allan Moffat Special #280 |
#14 | |||
Walking with God
I ended up replacing them with Rda slotted and QFM 500 pads, as part of the S1 to S2-3 upgrade. Much, much better. On the sedan, I replaced the stock gear with Rda slotteds and the same QFM pads, all good, great stopping power. GK
#15 | ||
These QFM pads seem to be getting a good wrap from those using them yet the only place I've ever seen them available is on Ebay. Anywhere else you can get them?
2024 F150 XLT
#16 | |||
Walking with God
GK
#17 | ||
Formerly known as TS 50
Does anyone bed there brake pads in?
No one has mentioned the bedding in process being completed.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
#18 | ||
the bendix pads dont say to bed in... says they are ready to use
i personally always bed my pads in.. but yeah
#19 | ||
Have a set of Kevlar pads an my XR6 series1
