Old 18-06-2008, 07:53 AM   #1
BFD83
BFD83's Avatar
Exclamation Getting the speedo calibrated
As the title says my speedo is out by 4ks, according to my gps. Where would i need to take the car to get it fixed?
Cheers!
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 09:10 AM   #2
RG
Back to Le Frenchy
RG's Avatar
Check the yellowpages under Speedometers. Plenty of places about that can do recalibration work.
Old 18-06-2008, 10:02 AM   #3
FGII-XR6
FGII-XR6's Avatar
bear in mind your speedo will change over time belive it or not tyre wear will cause your speedo to change, during manufacture they also tend to make them a bit over to be safe
[SIGPIC][/SIGPIC]
Rides:
Old 18-06-2008, 10:07 AM   #4
RG
Back to Le Frenchy
RG's Avatar
True, ADR's do state that the speedo needs to only be within 10km/h of the actual speed traveled.
Old 18-06-2008, 11:54 AM   #5
aye you
The Origional, The Best
aye you's Avatar
interesting, you'd think if the ADR's are allowing for 10km/h then you could contest speeding fines up to 10km/h over, since you may have actually been traveling the speed limit based upon the information you where getting from your speedo.
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 12:00 PM   #6
bloggs24
Ive always been under the impression that you wont get fined as long as your within 10kms of the speed limit, also dont fines start at 10km/h and over?
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 12:09 PM   #7
Cam
Stroking it...
Cam's Avatar
I believe this law changed a couple of years ago and is a fair bit stricter then it used to be
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 12:13 PM   #8
mattp
mattp's Avatar
That'd be nice, in Queensland it's 10% tolerance, but they don't advertise this, and in Victoria it's a lot less, I think it's 3km/h. I know I've had tickets down there for 63 in a 60 zone, and 104 on the freeway.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 01:14 PM   #9
im bak
also remember if comparing to a gps system, u have to be on totally flat land, if u going up or down a hill, the speed from the gps will be different from the speedo.
im bak is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 01:41 PM   #10
Peuty
Afterburner + skids =
Peuty's Avatar
I think you will find that only applies for being OVER the speed. As in they can't have speedos showing 10km/hr slower than you are actually travelling.
If that makes sense.
Oo\===/oO
Old 18-06-2008, 01:42 PM   #11
Peuty
Peuty's Avatar
And Brent, I wouldn't waste my time nor money with getting it calibrated, just think of it as free insurance against a speeding fine.
Oo\===/oO
Old 18-06-2008, 02:37 PM   #12
RG
Back to Le Frenchy
RG's Avatar
Sorry I stuffed that up, was thinking at 100km/h :
It is 10% either side of actual speed traveled.
Old 18-06-2008, 06:19 PM   #13
howesy
howesy's Avatar
Go to Jaycar and buy the kit for the speedo corrector. I have it in my car and it is tucked up under the dash giving me full 100% adjustability of my speedo. I can change rim and tyre sizes and diff ratios and a quick run with the GPS and it literally takes 5 seconds for me to adjust after working out the percentage error. The left dial takes it in 10% increments per click and the right dial 1% per click.
They are a pain to put together but and hoby person will do it for you at stuff all cost. Once made you just need to cut one wire at the back of the cluster and run it through the circuit board.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 06:29 PM   #14
HLC
Audi S3
but wont it through your odo out then?
Old 18-06-2008, 07:19 PM   #15
waggaclint
waggaclint's Avatar
Cheers!
id just leave it 4km is nothing its probably your GPS.....A mate of mine got booked for speeding a few weeks ago and his SAT NAV said he wasnt speeding..the police said that sat navs arnt acceptable whaen it comes to speeding....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 10:01 PM   #16
sly
Sly like a G6
sly's Avatar
But a magistrate isn't bound by what the police say. There was a case recently where the court wiped a fine due to a GPS log provided by the driver. In his case it'd be worthwhile to ask a solicitor who specialises in motor traffic cases.
Sleeper, anyone?
Old 18-06-2008, 10:27 PM   #17
bodes-sh
you'd actually be amazed at how accurate sat navs are. when i was in vic a couple of weeks ago, went through those speed check things they have over the hume highway, sat nav said 100km/h, speed shown on the speed check was 100km/h, speedo on the car was about 119 or something, this was a very late model subaru impreza, prob 05 or 06 not a wrx tho
Old 18-06-2008, 10:30 PM   #18
kocho
The Futuriser
kocho's Avatar
Yeah, same here bodes. The GPS' are amazing.
They are supposed to be around 3 - 4 k's out so the blame doesn't go to the manufacturer when your caught speeding.
Current Subaru Liberty MY08 2.5 SatNav
Previous 2003 BA Ford Futura.
CKGD - Freelance Graphic Designer
kocho is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 10:43 PM   #19
howesy
howesy's Avatar
No dead accurate just like the speedo. the wire you cut and run through it is the pulse wire. The pulse is altered I checked the distance covered on the gps as well.
ECU
Exhaust
Adjust. Rollers
Cold air
Old 19-06-2008, 09:40 AM   #20
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
bodes is right. the subaru's are notorious for being super innacurate.
Mine was 5 kays out with bald tyres, new tyres brought it back to the std 3ks.
Old 19-06-2008, 08:43 PM   #21
bodes-sh
sorry, just a correction, that should have been about 109 not 119 lol, they're not that far out...
