Old 21-06-2008, 04:36 PM   #1
eXi7w0unD
eXi7w0unD's Avatar
Default brake fluid
k so that little doobywacka or a container that has the brake fluid in, mines all cracked and corroding and has a hole in it the size of a small ant
are they easy to replace or should i take it to a brake specialist?
and if air get into it is that a bad thing? iv taped it up lol
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2008, 05:01 PM   #2
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
The resovoir is pretty easy to replace.
Air and brake systems is not good. Tape won't cut it, and from my experience, brakes are not something to be dodgey with.....
Not to be rude, but if you were unsure on the answere to your 'air' question, you should take it to a mechanic to fix.
good luck
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2008, 05:05 PM   #3
eXi7w0unD
eXi7w0unD's Avatar
what symtoms would i notice if air did get into brakes? cus this hole has been their for a while.... and i been driving fine. :S
im gonna call a brake specialist on monday to see what he can do for me!
i won.
Old 21-06-2008, 05:09 PM   #4
tex
Broken
tex's Avatar
Spongy / soft pedal, or depending on the amount of air in the system, no brakes at all..............
The air is also pretty easy to get out of the brake system, you would just need to bleed the lines...... eack brake caliper has a bleed nipple..... but, you MUST get the resovoir replaced first.
The Scud GT
Old 21-06-2008, 05:37 PM   #5
eXi7w0unD
eXi7w0unD's Avatar
yea, not really keen on taking the wheels off and bleeding. so ill take it to some 1
i won.
