05-07-2008, 03:10 PM | #1 | ||
Teh Baest
I've never heard this 'pinging' noise (which i suppose is a good thing!)
But i just got a capa flash tuner and am going to program the 98 RON tune into the ECU (car has run on only 98 RON in the last 18 months). Just want to make sure that if it does happen, i can identify it So besides sounding like a 'pinging' noise, what can u relate it to? Does it sound like banging on a tin can? The screech of brakes? The sound that used to be made off the old petrol pumps for every litre or gallon you put in the car? A bell? ANYTHING? Cheers
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
05-07-2008, 03:12 PM | #2 | ||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
like someone playing a musical triangle, or tapping a jar with a spoon, but the sound can vary.
2023 Superb Sportline - Steel Grey 2024 RS 3 Sedan - Mythos Black 2024 Mustang GT - Vapour Blue (built 31-10-2024 - waiting for ship) |
05-07-2008, 03:39 PM | #3 | ||
Barra Turbo > V8
Im pretty sure its called 'pinking' i could be wrong, thats what i was told
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
05-07-2008, 03:43 PM | #4 | ||
Afterburner + skids =
Damn thats a tough question mate. I would describe it as harsh/sharp rattling noise, but in saying that the only pinging I have properly heard is on my 308 engined ski boat and once in the XR8, but thats what it sounded like.
05-07-2008, 04:07 PM | #5 | ||||
AFF's 1st DM.......
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
05-07-2008, 04:13 PM | #6 | ||
Teh Baest
So, it's quite loud is it? Does it happen only at high revs? or throughout the rev range?
05-07-2008, 04:21 PM | #7 | ||
Usually at highish revs.
05-07-2008, 04:27 PM | #8 | ||
AWD Assassin
"pinging" sounds like rattling a small chain and it can also sound like a dull knock.......you'll more than likely hear it when the engine is under load...........taking off from the lights, going up a hill etc .........
05-07-2008, 04:37 PM | #9 | ||
a lot of people describe it like shaking a tin can with a few marbles in it.
It's volume can very according to how bad it is and different motors have different levels of how loud it can be. It normally only happens under heavy load situations, but it can even happen at cruise if there is a problem.
05-07-2008, 06:23 PM | #10 | ||||
Back to Le Frenchy
To me it sounds like there is a really small dude in the combustion chamber with a really small hammer trying to get out, really trying to get out. Mine used to get it at around 4000rpm, at max torque.
05-07-2008, 06:30 PM | #11 | ||
not here much anymore
Peutys description describes it best. Other way to find out is to let Herrod tune your car, then you'll hear it for sure.
2024 F150 XLT
05-07-2008, 06:35 PM | #12 | ||
my EB 5 litre used to do it around 4500rpm, but the thing sounded so good i couldn't stop pushing it harder anyway. only did it at high revs.
05-07-2008, 06:38 PM | #13 | |||
I miss my wheelbarrow
It can happen at any RPM, but always "heard" under heavy load.
Boosted cars will tend to make it down lower in the RPM, where a tuned NA car will be higher up. Its all a matter of cylinder pressure and ignition timing. Quote:
Daniel |
05-07-2008, 06:45 PM | #14 | ||
no one likes my description, i'm offended. Seems everyone has their own description. Put it this way, if you hear something from the engine bay that doesn't sound normal, while the car is going up a hill or reving, it's most likely pinging.
05-07-2008, 08:32 PM | #15 | ||
Its gone V
The best way to for listen for pinging that i ahve found is all windows up, and hold it flat in second (man 3rd) on freeway. if you think you got it then do the same thing in second with low load (slowly accelerate) if your sounds not there then go straight to your nearest drag strip and RACE!
06-07-2008, 11:33 AM | #16 | ||
Smile
Pinging is a metalic cracking noise and if bad it sounds like steel marbles .It can happen at any throttle opening and corresponds with the problem range in your car.
Causes of pinging can be too advanced ignition timing,lean fuel and heat. Contributors can be poor fuel quality,extremely hot weather ,poor cooling system or poor fuel system. etc. Pinging occurs as the events happen. Detonation is different.Detonation occurs when a hot spot occurs in the combustion chamber causing the fuel to cause a premature explosion.Results can be holes in pistons,bent rods etc.. Either way ..the fixes are similar.Better cooling,better tune or better fuel are some common fixes.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
06-07-2008, 11:38 AM | #17 | ||
oh so thats what that rattle is .
i did one tank of 91 the other week, then i put 95 in it last week. must burn off the rest of the 91!!!! : |
06-07-2008, 12:08 PM | #18 | ||
Broken
Happens under load, can happen anywhere in the rev range (depending on tuning) but most often heard at low to mid rpms.... mainly because the exhaust noise, mechanical thrash has not drowned out the pinging, as is the case at high rpms.
I like the description of it sounding like someone playing a 'triangle' from inside your engine. Best description so far. My description.......... hitting two large ball bearings together.... that sound in fast repitition.... coming from inside your engine. I have personally witnessed several people that simply can't hear it, one of them chose to ignore my advice to get the tune checked out due to the pinging under load in higher gears......... he could not hear it, ignored my advice and cost him several grand several weeks later. Thrashed car + pinging = broken engine eventually. Bent rods, smashed pistons, failed bearings.
The Scud GT 11.4 @ 128, 1.88 60ft. |
06-07-2008, 01:45 PM | #19 | ||
Sly like a G6
I've heard 3 slightly different sounds over the years. One is like a few marbles or ball bearings in a bag rattling (a kind of hard-edged rattle). Another is like a soft rattle, and the 3rd actually sounds like someone saying "pink". So Russell is right - it's "pinking" because it's onomatopoeic.
I've heard it quite distinctly when I had a u/s knock sensor, but used to often get it when launching uphill from a standstill on a hot day when the car had standard ULP in the tank.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
07-07-2008, 07:31 AM | #20 | ||
The best way I can decribe it is it sounds as though there's steel marbles in the combustion chamber. If you can imagine the sound those would make when the cars under load. The best way I've found to test for it is to start off at really low reves locked in 3rd gear and just floor it and if its going to pink it will do so at some stage through the rev range. Had a substantial pinking issue in my E49, that could only be solved by mixing in some avgas...
07-07-2008, 01:29 PM | #21 | ||
Irregular member
Put about 50 metal PC screws on the floor together, get your vacuum cleaner and suck them up. About the same as that?
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
07-07-2008, 01:39 PM | #22 | ||
Yes Dauphin, that is kinda how I would describe it, but less metallic.
Speed Kills. So buy an AU XR8 and live forever. Oo\===/oO Last edited by Peuty; 07-07-2008 at 01:45 PM. |
08-07-2008, 11:06 AM | #23 | |||
Actually ... that sounds about spot on to me ... I would have said rocks in a tin being rattled ... but the marbles on a tiled floor would be better described.
08-07-2008, 05:27 PM | #24 | ||
Fordless
It depends on the car & how bad it is but in my car it reminds me of rattling a chain.
08-07-2008, 09:11 PM | #25 | ||
i guess it could also be like shaking a can of spray paint, when the ball is rattling around inside, just a lot faster. mine did it badly about 18 months ago, put a new fuel pump in and it was a lot better, haven't heard it since then...
08-07-2008, 10:15 PM | #26 | |||
Critical Thinker
My subaru did this when I used 91 fuel. Completely stopped after using 98 fuel from then on. Went down to 95 fuel and it was ok too. But never ran it on 91 again. Horrible noise.
10-07-2008, 11:42 PM | #27 | ||
RC NITRO TRUCK addict
stand next to a V6 commo on start up, you will soon hear it
XR8 250 PURSUIT ,silhouette, manual, hardcover/spoiler FG F6 310 sdn XFT SY T awd terry LC GTR304 t350 9inch VK BT1 LSX 454R p/glide 9inch LX SLR LS3 p/g 9 current project |
