Old 15-10-2008, 10:25 PM   #1
AU00XR8
AU00
Default Out of Idea's HELP NEEDED PLEASE....
Hi All,
I have AU2 XR8 200kw. I have a problem at about 3000rpm. The car feel's like someone is holding it back it surges and shubbers. At 4000rpm it stops and takes off like someone has kicked it. This only happens when the motor is warm. From cold it is lovely it revs happily till redline through all gears.
No mechanic has been able to sort it. I have replaced spark plugs, leads, alternator, fuel filter and now the coil packs. Still there and the wallet is alot lighter.
Has anyone ever had this problem.
Thanks
AU00XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2008, 10:43 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Try starting the car and unplugging the MAF - if it runs no different with the MAF unplugged it could be stuffed.
Also check the air temp sensor is plugged into the bottom side of the intake pipe at the bend before the throttle body. It sounds like an odd problem you're having but if you can eliminate a few things and be sure it is getting air, fuel and spark, you should be a lot closer to finding it.
2024 F150 XLT
Old 15-10-2008, 11:10 PM   #3
EvilChief
Boost Addict
since u r saying that problem only occurs once car is hot, id start with coolant temp sensor. did any of your mechanics scan teh ecu for codes? or did a live data stream of all its sensors?
as said above hesitations often point towards AFM problems, but not always, once again ecu scan and live data can be the key here
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 15-10-2008, 11:55 PM   #4
sly
Sly like a G6
sly's Avatar
Other things you could try... a dyno run to check the AFR's... reset the PCM.
Sleeper, anyone?
Old 16-10-2008, 07:43 AM   #5
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Originally Posted by AU00XR8
Hi All,
Thanks
Fuel Pump, Fuel Pump and Fuel Pump!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 Okay!
Old 16-10-2008, 11:32 AM   #6
AU00XR8
AU00
Where do i find the MAF???
Old 16-10-2008, 11:42 AM   #7
RG
Back to Le Frenchy
RG's Avatar
It is what connects to the airbox. Metal housing with a black box on the side of it, passenger side front corner of the bay.
Old 16-10-2008, 04:21 PM   #8
AU00XR8
AU00
Okay i will try that tonight. But i rang Brad Garlic ford today. They said leads and spark plugs which have already been done. He said he thinks it could be a valve spring??
Old 16-10-2008, 04:41 PM   #9
Punnisher_42
There's your problem - why would you take it to a ford dealership of all places!
As if they'd know anything about a ford... :
Punnisher_42 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2008, 04:42 PM   #10
howesy
howesy's Avatar
Have to agree with the fuel pressure principle I would check the fuel pressure through the rev range it could even be regulator but If the pressure turns out to be dropping it would likely be pump. If pressure good all the way through then look else where but having had valve spring probs 3 times before I would be surprised if thats your problem as a broken one gives a miss all the way through and a weak one tends to keep stuffing up once it gets to the revs that cause bounce.
Anyway keep us posted will be interested to see what it is.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2008, 04:56 PM   #11
MNM96
MNM96's Avatar
Thats it, the broken valve spring works ok till it gets hot!
Did I mention
Fuel Pump, Fuel Pump or Fuel Pump!
I got sick of throwing money after everything, plugs, leads, coil pack, Pyro probe, filters. Even had Ford check out pressures. Car went like normal from cold, but no power at low revs when hot. Like you needed to push it to take off. Put a fuel pump in and smoked the back tyres the full length of the... um never mind! Made me realise that it was down on power when cold also, just not as bad.
Mike
Old 16-10-2008, 05:17 PM   #12
AU00XR8
AU00
It doesn't feel like its lacking power if anything it feels better than ever(that would have something to do with all the parts i have replaced). Im at a loss its been too 3 mechanics who all stood around scatching themselfs saying that it is a strange one.
Old 16-10-2008, 05:40 PM   #13
sly
Sly like a G6
sly's Avatar
What's cheap to check?
  1. MAF (as above)
  2. Catalytic converter... if it's flanged, drop it & look to see if it's blocked... x2 I suppose for a V8. That was a big part of my AU 6's lazy low-rev performance problems.
  3. Get the ECU scanned for error codes ($60 - $90)
  4. Fuel pump (NFI, maybe $100 or less if you can self-fit). If you have a vacc/pressure gauge you should be able to check the fuel pressure yourself. If so, do this before 3 above.
  5. Dyno run to check AFR's ($60 - $70 perhaps)
Beats paying a mechanic to scratch your, errr his, balls!
Sleeper, anyone?
Old 16-10-2008, 08:45 PM   #14
EvilChief
Boost Addict
$140 for a wallbro gss342, direct replacement
N12 Pulsar - sold
Old 20-10-2008, 12:41 PM   #15
AU00XR8
AU00
Okay have unplugged the MAF and the car ran like a pig so i am guessing it is not that. I put it into another mechanic who like all the other one's has no idea. It is not giving any error codes or that is what they are telling me anyway.
Old 20-10-2008, 10:04 PM   #16
MNM96
MNM96's Avatar
Old 21-10-2008, 03:23 PM   #17
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Sounds very similar to mine (except I'm 2 cylinders less than you). Mine does what you have described above, and my fuel pump isnt that old (although they can go pretty quick. Strange thing with mine is when on LPG it doesn't do it (so points towards fuel system) however if I reset the computer (disconnect the battery over night), then it runs perfect for about a week or so then starts doing it again. Mine was overheating when it would do it, but that was fixed with a coolant flush & change and new thermostat. Im still searching with mine, I have replaced Leads, plugs, cleaned air filter, cleaned throttle body and ISC, general service. At the moment I have other bills to pay and need tyres etc etc etc, so the searching is on hold for a while. Hope you figure it out soon.
Col.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2008, 03:41 PM   #18
FGII-XR6
FGII-XR6's Avatar
so are you trying to tell us it's the fuel pump????????????????????
[SIGPIC][/SIGPIC]
Rides:
Old 21-10-2008, 06:36 PM   #19
MNM96
MNM96's Avatar
Hard to pass a hint around here!
Old 21-10-2008, 10:00 PM   #20
mik
mik's Avatar
if every thing checks out can you unbolt the cat/cats and see how it runs with no back pressure? do you have lpg?
Old 21-10-2008, 10:04 PM   #21
bodes-sh
on another thought, have you been able to go to anyone with a scantool and take it for a spin with that hooked up? mainly to check engine readings, just to see what the ecu is seeing from the motor...
Old 22-10-2008, 06:56 AM   #22
au2sw
Blown 5L coming
au2sw's Avatar
forget fuel pump...itd do it right through rev range. not just drop out at mid range then kick in at high revs. im going with the cats and or o2 sensors.however, it doesnt take long for these items to heat up and if you have time to drive while the motor is cold and there is no problem....unlikely to be exhaust. but as you have tried everything else, it is possible. definitly go to Ford and get them to check ALL codes for you. they will be the only ones who will have the programmes for the entire ECU. other scantools will get the main items like has been suggested in here, but for more deeper problems, "public" scantools wont pick it up. i know we have had to send some cars to dealers to get hard codes checked out as our scantool wont read them.
good luck
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2008, 08:16 AM   #23
MNM96
MNM96's Avatar
good luck
I had the exact same symptoms, replaced the exact same parts, only to find it was the fuel pump. Admittedly, my car is a six, but the likeness of symptoms is uncanny!
Ford had the car for 2 days, found an old inactive Coil Pack code, but nothing else. this led me to replace a coil pack which was in perfect working order. (if you were to search 'threads started by me', you will find I gave the spare coil pack away to a member here) A shop with a scantool didn't find the coil code. another shop was requested to carry out a fuel pressure test. Another shop carried out a Carbon Clean. Add up the costs. $150 for plugs, $200 for CC, $80 for Coil Pack, $60 for Leads, $80 for Pyro. Filters, etc, + labour costs when used. Exhaust and Cat where less than 12 months, so I was confident they were ok.
Ford had replaced the Throttle Body, as the Idle Sensor was shot, and they couldn't undo it. I was starting to worry it was the problem, then a rep came into work with a specials list, with a fuel pump on it. Ordered one, fitted it, drama gone!
Mike
Old 22-10-2008, 07:25 PM   #24
AU00XR8
AU00
Okay, HINT takin and i will order a fuel pump. Now the question is what type would we go with??? Since i am getting one may as well get a nice, one that will handle a few extra KW's as next year i want to put a stroker kit in it.
Old 22-10-2008, 07:35 PM   #25
AU00XR8
AU00
Hey was just reading another post -xr8 220kw cuts out in 1st- and one of the post talks about the cam sensor????? Where is this and can i do it myself???? The squel that he talks about makes me thing that as mine make a squel as well???
Old 22-10-2008, 09:00 PM   #26
Stav
Smile
Stav's Avatar
The problem sounds to me that the ego sensors to ecu ..or ecu reading of the ego sensors may have an issue. Have you reset the ecu?
Old 22-10-2008, 09:28 PM   #27
AU00XR8
AU00
Yes i took power off the ECU overnight. Have also check the MAF. The squel is the thing that got me and everyone who has put there 2cents in.
Old 22-10-2008, 09:39 PM   #28
Stav
Smile
Stav's Avatar
Squel?
Old 23-10-2008, 06:38 AM   #29
au2sw
Blown 5L coming
au2sw's Avatar
sque A l
i think he means
Old 23-10-2008, 02:31 PM   #30
AU00XR8
AU00
sorry yes Squeal shouldn't of been drink typing....
