Old 19-11-2008, 03:43 AM   #1
Gonz
BA XR6T UTE - ANIM4L
Gonz's Avatar
Default AU fog lights?
did AU's ever come out standard with fog lights that fit into the standard AU falcons front bar?
cheers,
Gonz.
BA XR6T"ANIM4L" UTE UNDER CONSTRUCTION!
WA Member of proUTES.com : we need more FORDS!!
CHECK OUT MY OLD AU UTES!! IN HERE!
CHECK OUT MY OLD FG UTE!! IN HERE!!
CHECK OUT MY LATEST BA UTE!! IN HERE!!
YOUTUBE POWERCRUISE VIDEO!! CLICK HERE!!
YOUTUBE INCAR VIDEO!!CLICK HERE!!
Gonz is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 06:11 AM   #2
2fishingdogs
2fishingdogs's Avatar
No they didn't, but I have seen people custom make their own.
2006 SY Territory Ghia RWD in Seduce
With 3rd row seats, Velour Trim, Alloy scuff plates, deflector, Tinted windows & BF GT Lower Snorkle
www.bseries.com.au/2fishingdogs/terry
2004 BA MKI Tradesman Ute 1 tonner in Vibe
Tinted windows, Alloy scuff plates.
The rest is still stock as a rock
2fishingdogs is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 08:26 AM   #3
sikford
THE Fairmont Ghia 75th
sikford's Avatar
while on this subject, does anyone have pics of fog lights for there au's while still having the standard au bar?
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 08:34 AM   #4
JMO
JMO's Avatar
I wouldn't mind seeing some pics myself. I never understood why the EF/EL and BA/BF got fog lights that fit (rectangular) and are readily available aftermarket, but the AU didn't.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 09:25 AM   #5
Gonz
Gonz's Avatar
hmm, i didnt think so, weired ay? its the shape that makes it difficult to make, i would like it to look factory, i think ill need to look around at other makes and see if i can spot one similar in shape and retro fit it.
if any one has a good example of fog lights on AU's please post it up, i would like to see what it would look like,
cheers,
Gonz.
Old 19-11-2008, 11:55 AM   #6
sikford
sikford's Avatar
i have a few saved on my desktop at home so i will try post them up tonight for ya, i have been looking around a alot of other cars to find something that will fit alright
My Ride
My Build Thread
Old 19-11-2008, 12:46 PM   #7
b2tf
not here much anymore
b2tf's Avatar
Easiest way to do it would be to buy a light thats around 80-100mm in diameter and mount it behind the front bar so it 'fills' the brake duct hole if that makes sense. youd want one that is a rectangular shape so something a long the lines of the Hella "Comet" series would work well.
2024 F150 XLT
Old 19-11-2008, 01:24 PM   #8
broken_suave
broken_suave's Avatar
That only works if its a Series 2/3 XR front bar. The normal AU front bar is a little more tricky, with the curvy wedge shape.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 01:24 PM   #9
superroo
You can't stop the signal
superroo's Avatar
Kenz effort
Mechan1k
au3 chaser - Now kia chaser
DVL40L - Now BFwagon
Old 19-11-2008, 01:30 PM   #10
broken_suave
I'm planning on doing something very similar to AU3Chaser.
I'm also working on another fun little project to do with the XR bar.
Previously:
Old 19-11-2008, 01:35 PM   #11
superroo
superroo's Avatar
What is that out of curiousity? Is it modify the bar to fit the standard lights?
Old 19-11-2008, 01:40 PM   #12
broken_suave
In a way, yes. I am making an XR style front bar that is a direct replacement for the standard bar.
Previously:
Old 19-11-2008, 01:47 PM   #13
broken_suave
I did a very quick crude shop of what I'm talking about.
The finnished product will obviously be without the XR style grille. It will just be the lower section, so you can swap it over with any non XR AU Bar.
I stole the image from Russel, sorry mate, but it was the cleanest image I could find at the time.
This one has fog lights in the brake duct holes. Just to show what could be done. I've also increased the size of the airdam/radiator area, but this was just to play around. It may help if an intercooler is used.
EDIT: Please be kind :P I only had MS Paint available to me.
Previously:
Old 19-11-2008, 02:09 PM   #14
b2tf
b2tf's Avatar
: Gee I bet Russ wishes his car really looked like that!
2024 F150 XLT
Old 19-11-2008, 02:28 PM   #15
sikford
sikford's Avatar
lol at the above, but yeah i like the au3 chaser idea, similar to what i want to maybe do
My Ride
My Build Thread
Old 19-11-2008, 03:56 PM   #16
waggaclint
waggaclint's Avatar
you could probably modify a set of another type of car to go where au3 chaser had his you could remove the original plastic bezel and fit something in there check out ebay http://shop.ebay.com.au/?_from=R40&_...All-Categoriestheres heaps of different shapes and sizes....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 05:47 PM   #17
sikford
sikford's Avatar
just a few ideas to use... until ya actually have a good look and can measure up etc its only an idea.i will have to go into a mates work and check some cars out now,lol
ford focus 05-07
holden statesman
honda jazz
mitsubishi lancer 08
toyota camry 02-04
toyota prado
My Ride
My Build Thread
Old 19-11-2008, 11:59 PM   #18
Gonz
Gonz's Avatar
ohhhh, i like the Prado ones!! ill let you know what i find, ill be looking around now too!!
Gonz.
Old 20-11-2008, 07:24 AM   #19
b2tf
b2tf's Avatar
The Jazz ones look fairly close
2024 F150 XLT
Old 20-11-2008, 07:33 AM   #20
sikford
sikford's Avatar
yeah i might go check out the jazz and a focus, ill take one of the little black plastic bits with me, see wat i can work out. cant be too hard...
My Ride
My Build Thread
Old 20-11-2008, 10:06 AM   #21
broken_suave
The Camry ones look good too, mount them upside down in the corners of the standard bar.
Previously:
Old 20-11-2008, 10:55 AM   #22
rag top
rag top's Avatar
Anyone got a pic of the front bar on the car without the plastic inserts?
Would provide a better idea as to what has a better chance of fitting.
rag top is offline   Reply With Quote Multi-Quote with this Post
