Old 04-01-2009, 09:06 PM   #1
NC1183
NC1183's Avatar
Default Installing Amplifiers
Hey, just wondering what the best way people have installed amplifiers under their seats. Am about to embark on a setup change in my ute and as a part of that wish to put the amps' under the seats to get me back some room behind the seats.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2009, 09:21 PM   #2
SSD-85
It would double as a seat warmer too :hihi:
But seriously, I spose you could screw it into the frame that holds the foam in, depending on the size of your amp.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2009, 09:27 PM   #3
NC1183
NC1183's Avatar
Was meaning more on the floor under the seat then actually on the seat.
Nathan
The SP
The old ute (sold)
Build Thread
Old 04-01-2009, 09:37 PM   #4
SSD-85
Well AFAIK there's nothing that one could accidentally screw into on the floor, so I don't imagine any problems.
Old 04-01-2009, 10:03 PM   #5
brad`
The Monty
brad`'s Avatar
if u decide to do it to the chair, find a series 1 fairmont with the cd stacker under the chear and take a look how thats held up/in
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 12:11 PM   #6
sikford
THE Fairmont Ghia 75th
sikford's Avatar
your fine mounting it under the seat but definatly dont mount it upside down as all you will do is cook the amp as well as the passenger's a**.lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 07:59 PM   #7
Mechan1k
Mechan1k's Avatar
I had mine screwed into the floor under the driver's seat ... it was a Pioneer 600W 4-ch.
Look near the early pages of my AU build thread in my signature ... there's a pic of it peaking out from under the driver's seat. Was a tight fit.
My sub amp was bolted to the trans tunnel ... on a flat piece of carpeted MDF (kinda false floor) ... between the subs ... it was solid indeed.
Old 03-02-2009, 05:18 PM   #8
adrian k
adrian
adrian k's Avatar
where did you guys take the 'auto on' power to the amp? ignition on? antena power?
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2009, 05:23 PM   #9
TOASTED
JMM modded EF
velcro is an easy option. amp must be mounted right way up tho otherwise itll overheat.
Originally Posted by ILLaViTaR
Guess the alcohol tax is turning people to mind altering drugs.
I drive : A heavily modified EF Fairmont with a JMM dev5 cam, worked head, 3.5" mandrel bent intake, exhaust, and a few other bits n pieces like a stally etc.
"She goes like a zirtek"
WANT A FAST FORD RING THIS BLOKE V V
Abbott Engines for HeadWork
20 years experience
PH Rob on (07) 5526 3883
TOASTED is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2009, 05:24 PM   #10
TOASTED
JMM modded EF
your head unit should have a remote out wire. use that for auto on.
20 years experience
Old 03-02-2009, 06:42 PM   #11
ronwest
All Bran = Regular Member
Same here... amp under front passengers seat held in place with a couple of velcro strips.
I got my velcro (not too sure how long the roll was... maybe two metre's?) from Bunnings for around $20.
Old 03-02-2009, 07:58 PM   #12
adrian k
adrian
adrian k's Avatar
sorry, i should have been more specific. i am still running the factory 6 stacker
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 03-02-2009, 09:33 PM   #13
Ride
Stay Classy ™
Ride's Avatar
In my AU Ghia (sedan) it has a remote turn on wire that goes along with the RCA to the boot where the factory amp is, should be a 4 pin black plug, the control wire is red from memory.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 11:57 AM   #14
adrian k
adrian
adrian k's Avatar
thats on the premium head unit, this is just the standard one, so no RCA outs or amp on wires...
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 04-02-2009, 12:50 PM   #15
Ride
Stay Classy ™
Ride's Avatar
In that case you'd have to set up a manual switch or splice into the acc wire from the headunit, not sure how else you would go about it
Old 04-02-2009, 02:40 PM   #16
adrian k
adrian
adrian k's Avatar
yeah, i was thinking the acc wire would do the job. don't like manual switches as they can be left on by accident.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 04-02-2009, 05:29 PM   #17
NC1183
NC1183's Avatar
Depends on the amp, if your using one with speaker level inputs because you have't got RCA output, some of them have turn-on on signal detection.
Nathan
The SP
The old ute (sold)
Build Thread
Old 04-02-2009, 07:55 PM   #18
adrian k
adrian
adrian k's Avatar
na, looking at hooking up my old Alpine amp/sub box, and just running a speaker-line level converter off the rears.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
