06-01-2009, 12:11 AM | #1 | ||
Teh Baest
Been a pretty bad squeaking noise while turning left for the past week or two, doesnt happen all the time either... Usually right at the beginning when i start her up but after i have taken a few corners, she is quiet.
What's the go u reckon? Hubs? Bearings?
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
06-01-2009, 12:20 AM | #2 | ||
Handbrake shoes...
06-01-2009, 08:54 AM | #3 | ||
T3/Sprint8
Be more specific, from where front rear ? you say at start up, are we talking engine area or undercar ?
06-01-2009, 12:10 PM | #4 | ||
Teh Baest
Sorry,
It sounds like it is coming from the front left. It's not when i start up as such, it's within about the first 3-4 minutes I am driving when i turn left, sometimes in the very beginning (first 10-15 secs of driving) even when i drive straight.
06-01-2009, 12:18 PM | #5 | ||
T3/Sprint8
I had a squeak in my XR8 similar to that and it had me stuffed where it came from.
Bugger me was the upper ball joint, being encapsulated/non greasable this shouldn't happen but I suppose there's a start for you. Another could be lower inner control arm bush's or other bush's but being one side get the b/j's checked first.
06-01-2009, 12:20 PM | #6 | |||
Back to Le Frenchy
I had the same sound, balljoint it was.
06-01-2009, 01:26 PM | #7 | ||
yep had the same too mine was lower front left ball joint.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
06-01-2009, 02:02 PM | #8 | ||
Irregular member
Mine's currently doing this on and off - random squealing during left turns. If I cycle the handbrake lever a tiny bit while moving, it goes away. Always had problems with my handbrake since owning it.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
06-01-2009, 02:06 PM | #9 | ||||
Back to Le Frenchy
06-01-2009, 04:00 PM | #10 | ||
...Russ its a Ford.. or did you forget? I've had mine 'fixed' a few times now... fixing a Ford handbrake doesnt mean it will work after you fix it :P
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
06-01-2009, 04:08 PM | #11 | |||
Teh Baest
Thanks for the help fellas, i'll get my mechanic to look at the ball joints when he reopens
06-01-2009, 05:36 PM | #12 | |||
Irregular member
07-01-2009, 07:48 PM | #13 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
07-01-2009, 07:54 PM | #14 | |||
BOSS Pilot
I had a noise like that after I tightened up the handbrake when selling my old au. Couldnt work it out for a while but a huge pull on the handbrake and it went away. Think I nearly ripped the lever off
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
18-01-2009, 05:23 PM | #15 | |||
When was this Dauphin? Call up Matt at Bink's Footscray he help you out
The car is perfect when nothing more can be removed from it. 08 FG GT-P |
19-01-2009, 10:34 AM | #16 | ||
Irregular member
It was years ago now. I actually had some more issues with it this weekend just passed. It would start squealing when I move off from being stopped at a red light. Horrible sound. Tried all sorts of things, stopped by the end of the day.
