Old 07-01-2009, 12:32 PM   #1
aufairmontghia
XR6
aufairmontghia's Avatar
Default Au Boot Strut Mount Rusted
Hi Guys
My AU S1 Fairmont Ghia has rusted the boot strut mount!!!!
The stud bolt which holds the boot strut & mounts to the body on the lower end has rusted through. The mounting point & the bolt have rusted so the strut hangs freely....
The boot is bloody heavy now being held by the left strut only & slams down real hard when trying to close it carefully. Have taken right strut off to minimise damage from the loose strut.
Has anyone out there experienced this on their AU????
Any ideas on how to repair or have had their AU repaired successfully?????
Cheers :
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 12:59 PM   #2
st33l3y
Pursuit #144
st33l3y's Avatar
Yep, had the same problem on my AU3 XR6. I made a new bracket to essentially fill the old hole, cut the thread off the ball joint to which the strut connects and welded that to the bracket. I'd post up a pic but I'm at work unfortuntely.
Alternatively, you could weld the ball joint back into the body of your car.
2003 FPV Pursuit #144
| Silhouette | 5 Speed Manual | Pacemaker Twin 2.5" System | Pacemaker 2.5" 200 cell cats | Pacemaker 1 3/4" headers | Yella Terra airbox | Herrod Oil Breathers | MGW Short Shifter | 19" Bonspeed Clutch billet wheels | Spoiler Deleted |
st33l3y is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 07:39 PM   #3
aufairmontghia
XR6
Yeah thanks st33l3y,
Sounds good to me... The only thing I'd want to do a good job if I was tackling it myself!!! U would wanna get a factory finish if you can....
When it comes to welding I'm not overally comfortable & worry I'd probablely
go through the panel!!!!!
I hope to see some pics of your handy work....
Cheers used:
Old 07-01-2009, 09:06 PM   #4
fourl6
AU Falcon Man
fourl6's Avatar
yeah iv noticed mine has a bit of rust around the lower bracket of both struts...
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 09:20 PM   #5
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Happened on my BA last week too
The metal plate they screw into gave way (never found it) found a nut that suits the thread and a couple of washers (one inside, one outside) and bolted it back in
Had to weld the nut to a piece of wire to hold it, cant get hands in there
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2009, 12:22 AM   #6
GK
Walking with God
GK's Avatar
There's a thread here somewhere about how to fix it.
Someone should be able to locate it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 08-01-2009, 12:29 AM   #7
747jet
2 4 turning 2 4 burning
747jet's Avatar
its normal my sisters au 1 has the same thing happening its getting bad have to cut it out drill and tap and fit a new ball joint i hope that will work
747jet is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2009, 01:37 PM   #8
aufairmontghia
XR6
Hi All,
Rang ford parts this morning about problem???
The guy I spoke to said the strut mount was one piece & welded to the body...
He's getting it in from the warehouse & will let me Know when it comes in so I can have a look at it!!!
I believe its a one piece plate with the stud mount attached to it from the factory.
Will let u all know how i go????
Old 08-01-2009, 03:27 PM   #9
sikford
THE Fairmont Ghia 75th
sikford's Avatar
may have to look into this myself, its a pain in the **** but oh well, not much ya can do besides fix it.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2009, 07:19 AM   #10
aufairmontghia
XR6
Hi Guys,
Got some pics of my rusted mount & the replacement panel from Ford today.
There $25 for the part but not sure how they mount to the body....
Any ideas as the existing would have to be cut/grinded out & new one spot welded???
Old 09-01-2009, 07:49 AM   #11
sikford
sikford's Avatar
do you have the part number for this item as i think a few ppl may have to buy one?
My Ride
My Build Thread
Old 09-01-2009, 09:48 AM   #12
fourl6
AU Falcon Man
fourl6's Avatar
i think most of us will be scared of the price to get it fitted :
Was
Old 09-01-2009, 09:50 AM   #13
sikford
sikford's Avatar
definatly an issue i think...
My Ride
My Build Thread
Old 09-01-2009, 09:56 AM   #14
fourl6
AU Falcon Man
fourl6's Avatar
good excuse to get the car into a panelbeater tho... i have a few little things id like done :
would there be anything i could spray on mine to reduce the cancer... mines not that bad but id like a sort of preventative
Was
Old 09-01-2009, 10:06 AM   #15
aufairmontghia
XR6
All
Will check the part no. when I get home... At work at the moment & checked the invoice but may be different???
I don't know about fitting price but imagine if the welds etc.. can be unpicked
easily, anyone could do it????
I think its still a bit of work to repair rust/hole in it self, so maybe its a good
alternative!!!
Old 09-01-2009, 08:17 PM   #16
aufairmontghia
XR6
Hi All,
Iv'e had a look at the part. Part no. is ER F28126 A
Old 10-02-2011, 07:02 PM   #17
Bricki
I went to the wreakers and got myself a strut mount for a commodore for $5 and which is a L shaped plate with the mounting ball & bolt attached.
Bricki is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2011, 01:08 AM   #18
T3man
T3man's Avatar
So what are you doing here if you have a Commodore?
Shouldn't you be down the pub drowning your sorrows?
Old 11-02-2011, 09:24 AM   #19
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
First off i don't think he has a commodore, he just used a part
and also, you're not funny.
Old 11-02-2011, 11:16 AM   #20
T3man
T3man's Avatar
And you're not all that pretty; but did I say anything?
Old 11-02-2011, 04:00 PM   #21
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Got any pics? Would like to see how you did it.
UK
Old 11-02-2011, 07:25 PM   #22
hendoau99
app diesel mechanic
common problem on AU's. mines got a small amount. all i do is wipe out the whole boot/ water run off area with a chamois a few times after washing the car and spray a bit of wd40 or rp7 over the brackets. it's working so far....
daily driver: au series 1.5 forte sedan
mods: clarion head unit, 15" alloys, ex police sump guard, futura grill,clear side flashers, AU s2 tailights,BA xr6 spoiler, kenwood 12" sub, kenwood 250W amp, kings sports lows, 2.5" lukey catback.
mods to come: rims!!
hendoau99 is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2011, 08:58 PM   #23
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
the AU is also showing signs of this around its rear mounts but as its a wagon and has rust right around the hinge on both sides :(, would ford carry the part for the wagons?
and also i found a heap of rust in the rear left dogleg today :( any ideas as to wether ford carry the rear doglegs?
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2011, 10:55 AM   #24
hendoau99
app diesel mechanic
ford should have the hinges, if they do have doglegs, it will be at an unbelievably dear price.
Old 12-02-2011, 10:59 AM   #25
XRGhia
meh.
XRGhia's Avatar
well i have to repair the rust before we even consider selling it
will hit them up and see what they say
Old 12-02-2011, 11:34 AM   #26
347 mont
347 mont's Avatar
Mine is going, going not quite gone.Common problem as stated previously.
Let us know how get on with the replacement part,
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2011, 12:03 PM   #27
mik
mik's Avatar
the lower ball socket on mine on the rhs had a small amount of rust just enough so when i put a bit of extra force on it while changeing the worn out struts it completely pulled out of the body work, i bought a bit of aluminum angle cut it down to size and mounted it in the channel with a new ball and some matching paint, not pretty but does the job.
Old 18-12-2011, 01:21 PM   #28
FG Brake
Default Re: Au Boot Strut Mount Rusted
Ford no longer even sell the bottom fitting. Gosh they could make a $million.
I priced the socket bolt alone and that was $11. Off to the wreckers to see if they have some bolts that survived fords leaky boot problems.
FG Brake is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2011, 12:00 AM   #29
GK
Walking with God
GK's Avatar
Mine packed up a few days ago too.
Will have a look at mig welding the ball to another piece of square metal, then welding that to the existing piece.
GK
Now gone!
On LPG
Old 19-12-2011, 11:25 AM   #30
mik
mik's Avatar
it`s easy enough to repair except for the paint damage, thats why i did the dodgey way i did it, the bolt in ball you can buy from most bearing places.
