Old 14-01-2009, 09:46 PM   #1
XR82GO
AU XR8 UTE
XR82GO's Avatar
Default 2 piece tailshalf
I have a 2 piece tailshaft...is fully reconditioned...how much would it be worth...any ideas guys
Current Rides:Series 11 AU XR8 Ute & Series 1 AU XR6 Sedan
Extreme Big Boys Toys
www.utez.com.au
Rum Runners Ute Club
XR82GO is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 11:28 PM   #2
waggaclint
waggaclint's Avatar
what does it suit sedan/ute/wagon ??
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2009, 02:56 AM   #3
The Monty
Just slidin'
The Monty's Avatar
Auto or manual?
MD Mondeo - For the family
NP Pajero - For the adventure
Old 15-01-2009, 09:38 AM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
a 2 piece tailshaft is as useful as a rear wing. I never go over 180 to make use of it anyway.
Old 15-01-2009, 09:39 AM   #5
RG
Back to Le Frenchy
RG's Avatar
That's nice but what has that got to do with the value of it?
Old 15-01-2009, 09:43 AM   #6
Mr Hardware
true. i wouldn't say it'd be worth too much. usually it'd cost ya $150 or so for the middle cv-joint to be redone, so say, $200? Maybe more if someone's really keen?
Old 15-01-2009, 09:52 AM   #7
Stav
Smile
Stav's Avatar
I was quoted around 800 from memory for a recoed one ..
Old 15-01-2009, 10:06 AM   #8
b2tf
not here much anymore
b2tf's Avatar
I believe it is to suit an Auto V8, its basically a Pursuit 250 one but Rob will confirm that.
2024 F150 XLT
Old 15-01-2009, 10:26 AM   #9
Stav
Smile
Stav's Avatar
Thanks for clearing that up ..I never knew they came standard. cheers.
Old 15-01-2009, 10:42 AM   #10
Mr Hardware
Yeah, two piece tailshafts came standard with lots of things, just not stocko forte's and fairmonts.
Old 15-01-2009, 11:04 AM   #11
XR82GO
AU XR8 UTE
XR82GO's Avatar
Yes it is for an Auto and it is for a ute as far as i know...will get a pic up of it soon
www.utez.com.au
Old 15-01-2009, 01:03 PM   #12
b2tf
b2tf's Avatar
The only AU that ever got one was the P250 as it was designed to be this way so it could go over 180km/hr. Taken from the FPV website:
To cover the extreme working conditions and heavy loads that many Falcon utes are subjected to, the standard ute has a long, large diameter tail shaft required for the substantial variations in rear axle ride height and work load. This also provides stand alone rear suspension that is not dependent on the type of cargo body fitted. To cater for these extremes in application, the standard ute has a 180 km/h speed limiter which makes sense given its unrivalled heavy duty work focus.
However, the premium performance and extra recreation focus of the Pursuit 250 allowed Tickford to take a different approach to the driveline. The challenge was to find a tail shaft design that maintained the ruggedness of the standard design while catering for the massive torque loads imposed on the driveline by the powerful new engine and to be able to sustain these loads at higher rotational speeds. Tickford could also reduce the payload and lower the ride height to set up the suspension specifically for this application without having to cover the extremes that a one tonne payload will generate. This approach also ensures that high speed handling is consistent laden or unladen.
After extensive outback testing, the answer was found in a two piece tail shaft with a combination of double cardan and constant velocity joints. Because of Ford's strong owner base in parts of outback Australia that are subject to an open speed limit, high speed stability and durability under sustained high speed cruising when empty or loaded were higher priorities than the ultimate load carrying ability of the standard ute.
The resulting two-piece tail shaft was a first for a leaf spring live rear axle ute and the lack of vibration under the enormous twisting power of 500 Nm of torque was a revelation to all who have driven a Pursuit 250. The ute's extra long wheelbase, the even spread of weight into the rear section generated by the hefty structural members, the constant rear track and the advanced front suspension and steering generated a new benchmark for a performance ute, laden or unladen.
Rest is here:
http://www.fpv.com.au/theheritage/ut...50utility.aspx
2024 F150 XLT
Old 15-01-2009, 01:44 PM   #13
The Monty
Just slidin'
The Monty's Avatar
So what will it fit?
Old 15-01-2009, 03:59 PM   #14
Mr Hardware
wow, my bad. i was under the impression that anything with an XR badge or higher had a two-piece to get around the 180k issue. ignore me then, looks like they're rare.
Then why do commodores have two piece tailshafts if they are of no advantage? (no holden bashing pls, serious question).
Old 15-01-2009, 04:52 PM   #15
b2tf
b2tf's Avatar
Just a design thing really, I know which out of a 250 or a Commodore I'd rather be doing over 180 in though.
2024 F150 XLT
Old 15-01-2009, 04:52 PM   #16
b2tf
b2tf's Avatar
Ute or Wagon
2024 F150 XLT
Old 15-01-2009, 06:12 PM   #17
josh_hartman
i thought the tailshafts are unsafe over 180kmh so why isnt my xr8 speed limited if its a single peice?
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2009, 06:14 PM   #18
The Monty
Just slidin'
The Monty's Avatar
Ive heard it lots, but having seen mine on the dyno a few times at over 200, I dunno.
Old 15-01-2009, 06:53 PM   #19
RG
Back to Le Frenchy
RG's Avatar
Because the XR8 sedan got an alloy shaft.
Old 15-01-2009, 08:49 PM   #20
b2tf
b2tf's Avatar
Utes are speed limited, sedans arent.
2024 F150 XLT
Old 15-01-2009, 09:38 PM   #21
philstoj
philstoj's Avatar
Utes got the alloy tailshaft aswell, just its about 10 ft longer than the sedan!
Old 16-01-2009, 03:33 PM   #22
XR82GO
AU XR8 UTE
XR82GO's Avatar
ok guys here is something i found out today
Rang Sinclair Ford and asked for a price on a 2 piece tailshalf.
He asked me if i was sitting down as he couldnt believe the price that was on his computer screen
$5125 plus gst
So you do the math..
Over $5500 for a new one
www.utez.com.au
Old 07-02-2009, 02:15 AM   #23
joolz
$5125 plus gst
Thats a joke!!! So its for an AU? and has a slip yoke, UJ, front tube(approx 400mm), centre bearing, CVJ, rear tube (approx 1000mm) and double cardin joint (2 UJ's in one joint). If its a reco i would pay no more than $400 for it as its more than likely genuine components werent used. The genuine UJ's are Spicer and CVJ is GKN.
joolz is offline   Reply With Quote Multi-Quote with this Post
