Old 18-01-2009, 12:20 PM   #1
old fordnut
too many fords
old fordnut's Avatar
Default Brake lights
Both brake lights arent working in the xr8. Both bulbs look okay, fuses ae good. What else could it be? Brake switch maybe?
old fordnut is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2009, 12:23 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
is the HI veiw out as well?
Originally Posted by Riksta
Old 18-01-2009, 12:41 PM   #3
old fordnut
too many fords
doesnt have a globe in it. I put a test lamp on the brake switch and has power on one pin but not the other. Is it supposed to have power on both?
Old 18-01-2009, 12:47 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
The switch should have power to one side then when its open should complete the circut . if you remove both wires from the plug and join them with a bridge your brake lights should work(ignition on) ,indicating a faulty switch . if you still have no light but have power move back to the Globe end and check the conections for melted fittings as this is a issue with the AUs
Old 18-01-2009, 12:49 PM   #5
old fordnut
too many fords
checking now
Old 18-01-2009, 12:55 PM   #6
old fordnut
too many fords
Brake switch is dead. Can I get these from repco or somewhere? How much are they?
Old 18-01-2009, 01:05 PM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
yeah you can get them from repco, supercheap etc
from memory they are cheap, like $15 or so or something not to big
Old 18-01-2009, 01:07 PM   #8
old fordnut
too many fords
sweet. better go get one
Old 18-01-2009, 01:22 PM   #9
The Monty
Just slidin'
The Monty's Avatar
If you havent left, wait and go to Ford and get one. The aftermarket ones arent good, and usually dont work as the springs in the switch are the wrong rate. Its better paying the extra $10 for a quality one that works, and doesnt need to be stuffed with to make it work.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 18-01-2009, 06:56 PM   #10
InfernoSR
Sales Representative
InfernoSR's Avatar
I'm wondering if this is the same fault mine has... as mine are working on the odd occasion... one side is now out i just noticed... where as the other side is weak and flashy... they were playing up when i bought it...
Old 18-01-2009, 08:38 PM   #11
The Monty
Just slidin'
The Monty's Avatar
That sounds a little different to when a brake switch goes. When a brake switch goes, all your brake lights will go at the same time.
Old 18-01-2009, 08:58 PM   #12
InfernoSR
InfernoSR's Avatar
Bugger... sounds like half the switch is gone then :P
