Old 20-01-2009, 08:17 PM   #1
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Default Strange humming noise while idling
First things first, yes it's not the engine...... :togo:
I swear it's only been the last couple of days......start it up.....and while it's idling.....there is the slightest low whirring noise...very quiet...it sounds a bit like an amplifier running, except i only have the factory one at the moment, and it does this with the radio off.
sounds like its coming from somewhere at the back end of the car.
doesn't appear to affect driveability or performance, but now i've heard it, it bugs the hell out of me.....dunno if it's just me hearing things, but I'm positive it wasn't there a few days ago.
Does anybody have any idea what it could possibly be???
Dave
Old 20-01-2009, 08:20 PM   #2
LukeyST
ST fan
LukeyST's Avatar
Fuel pump id say.
Mine hums quite loudly, especially when your standing outside at the back of the car.
Cheers,
Luke
2013 Focus ST in TANGERINE SCREAM
2003 Focus Zetec in COLORADO RED
LukeyST is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2009, 08:22 PM   #3
Dave_Obsession
Now that you've mentioned it Luke, I've checked the car idling and standing outside.....and there wasn't any noise that wasn't meant to be there........
Old 20-01-2009, 08:29 PM   #4
LukeyST
ST fan
LukeyST's Avatar
Oh ok, well at idle with the car not moving, theres not much else going on at that end of the car. Someone else might have the answer however!
Luke
Old 21-01-2009, 06:04 AM   #5
V8 EF Fairmont
I had a similar thing, but it was coming from the dash, and it turned out to be that I hadn't turned the vent switch (the one that chooses demist, face, feet etc.) to the right setting properly. Moved it to the setting proper and the noise stopped.
V8 EF Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2009, 11:00 AM   #6
broken_suave
broken_suave's Avatar
My fuel pump went through a stage of being really noisy, and then quietened down again, I dont understand, but its back to normal now. Perhaps it was a similar situation?
Perhaps the fuel filter needs changing, causing the pump motor to load up? I dunno..
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2009, 11:07 AM   #7
RG
Back to Le Frenchy
RG's Avatar
Sounds like the fuel pump to me.
Old 21-01-2009, 07:03 PM   #8
sooty43
I reckon its the fuel pump. Pour a bottle of upper cylinder lube into the fuel tank, it might just free it up . All you can lose is ten bucks.
sooty43 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2009, 11:52 PM   #9
scrivens
quarter pane
scrivens's Avatar
That's what mine was - sort of hiss/hum. Took the vent panel off to see if any of the little switch hoses had come off and found it was just the switch itself not quite on the position mark. Very quiet and annoying noise.
Does sound like the fuel pump though as the vent noise is definitely in the cabin.
scrivens is offline   Reply With Quote Multi-Quote with this Post
