Old 22-01-2009, 09:49 PM   #1
Blue_XR
Blue_XR's Avatar
Default Checking air filter
im just wondering how to check the air filter on my sisters focus. I started to remove the screws holding the airbox lid down but i realised i need to remove the pipe from the airbox lid to the throttle body because i couldnt access some screws.
My problem is i dont know how to remove the '0' clamps holding the pipe on to the throttle body. Is a special tool needed to remove and take it off??
Blue_XR is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2009, 09:55 PM   #2
Loris
Focus & Territory TDCi
what type of focus?
on my tdci its pretty easy.. 4 screws (i think, its been a while) all can be access with a ratchet, no need to take off any piping
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2009, 09:59 PM   #3
Blue_XR
Blue_XR's Avatar
I dont know the model, but its a late 06 model, so current shape.
I had trouble taking it all off and i think its more than four screws. I tried it a while ago now, but i stopped cause i couldnt access one of the screws. I only want to check it now cause the 30 thou service is coming up
Old 22-01-2009, 10:30 PM   #4
b2tf
not here much anymore
b2tf's Avatar
If it does have the round silver clamps on the hose they will only be a hose clamp which you can loosen with a flathead screwdriver until it moves enough. You should be able to lift the lid off the box with the intake pipe still attached though.
2024 F150 XLT
Old 23-01-2009, 08:54 AM   #5
Blue_XR
Blue_XR's Avatar
They are not regular hose clamps that's why im asking
Old 23-01-2009, 10:30 AM   #6
BlackLS
yum
Yeah use a flat head, there is sort of a little hook that you get the screw driver into and lever the clamp off. Make sure you replace it with a regular hose clamp.
2005 LS Focus LX
250,000kms.
Old 23-01-2009, 11:03 AM   #7
Blue_XR
Blue_XR's Avatar
Thanks BlackLS, so there is no way to get it back on?
Old 23-01-2009, 11:26 AM   #8
BlackLS
yum
Yeah there is, either with some long nose pliers or 2 flat heads, or a combo of both... but a screw on clamp that costs 20c at Supercheap gets my vote.
2005 LS Focus LX
250,000kms.
Old 23-01-2009, 11:39 AM   #9
819_FLY
819_FLY's Avatar
Plus the worm drive hose clamp will see a few more uses than the once only clamp type that Ford use.
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2009, 01:17 PM   #10
BlackLS
yum
Considering Ford only change the air filter for the Focus after 60,000kms.
2005 LS Focus LX
250,000kms.
Old 23-01-2009, 01:19 PM   #11
Blue_XR
Blue_XR's Avatar
ok thanks for that will recheck it again this weekend
