Old 23-01-2009, 04:14 PM   #1
JMO
JMO's Avatar
Default Removing PCV Valve
Can someone tell me how the PCV valve comes off the top of the rocker? Is ti simply a case of pulling it or is there a twist or something?
While on the topic, does anyone know how much it would cost for a replacement?
Cheers.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2009, 04:22 PM   #2
HARMFUL 81
Cheers.
FYI When you replace the pcv valve, be sure to check the grommet to the rocker cover. My brother just replaced his pcv due to rough idle, but it wasnt rectified till he had replaced the splitting grommet aswell.
HARMFUL 81 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2009, 04:27 PM   #3
JMO
JMO's Avatar
Rough idle you say? I've been looking for the cause for over a year! I was just trying to get it off so I could take the top off the BBM. I'll try replacing it tomorrow. Any idea on cost?
Still don't know how to remove it though. I don't want to break it.
Old 23-01-2009, 04:33 PM   #4
HARMFUL 81
he said its a relatively cheap part in the order of $20-25. I assume its just a matter of pulling it straight out
Old 23-01-2009, 04:36 PM   #5
JMO
JMO's Avatar
Thanks for the help. I'll just give it a good yank.
Old 23-01-2009, 07:11 PM   #6
The Monty
Just slidin'
The Monty's Avatar
Bit of a twist to get it moving freely. Pull it out, and plug the new one in.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 25-01-2009, 10:13 PM   #7
au2sw
Blown 5L coming
au2sw's Avatar
also be sure all of it comes out...the pcv's have a tendancy to break around the bottom and leave the metal bits sitting in the rocker area....unlike older models thoughm the au catches the bits so they dont go into the timing chain and really cause damage. a magnet on a stick or even a magnetised screw driver will work at pulling the parts out. cost is around $15 max and thats for a steel one....much longer lasting and wont break apart on you. and yes, you just pull the valve straight up after twisting to free it fromm the gromet.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2009, 05:19 PM   #8
Arkturus
Arkturus's Avatar
Hi, just wondering how you went with this, if it fixed your idle problems?
My EL has rough idle on gas and petrol and when i pull the vaccum hose off the PCV and stick my finger over the end the idle comes good.
Is that a good sign the PCV is stuffed?
Arkturus is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2009, 05:53 PM   #9
JMO
JMO's Avatar
I swapped the PCV over with a new one and there was no change. I haven't tried changing the rubber retainer yet, but I'll let you know how it goes.
If the revs increase significantly, the PCV is most likely alright but it may be worth changing the retainer as HARMFUL 81 suggested.
When I placed my finger over the vacuum hose, the revs went up so the roughness went away. The problems I'm having are between 700-800 rpm.
