Old 28-09-2009, 09:03 AM   #1
BillC
Default Missing when cold
Just when I think I have everything sorted out another problem occurs....
Car: AUXR8 III auto
Problem: missing when its cold (for about 5 to 10 minutes) then the car runs fine.
When the car is cold it runs like its coughing and spluttering. When its hot the car runs absolutely normal. I have never seen a fault like this. Normally its the other way around. Car cold runs good then when hot bad.
Please help ????
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 02:15 PM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
may be a sticky valve???
not sure really.. but had a car that did the same thing and was told that..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 03:14 PM   #3
BuckTooth
Feel the boost
BuckTooth's Avatar
its not the spark plugs is it. only a suggestion but worth checkin out i guess.
BuckTooth is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 03:50 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I thought my car was missing when cold, turns out i just couldn't see it through the fog.
Old 29-09-2009, 04:09 PM   #5
KR1STO
KR1STO's Avatar
hahahahaha... gold
see my car here:
[SIGPIC][/SIGPIC]
Old 05-10-2009, 02:06 PM   #6
BillC
For those interested. ABout 6 months ago I talked on this threat about a fault where the car occasionally had like a miss or a pause and then it was OK for a while then played up again. That turned out to be the CAM Angle sensor.
This time its the crankshaft angle sensor. Yes, it turns out we have both. At least its fixed now.
Old 05-10-2009, 02:12 PM   #7
KR1STO
KR1STO's Avatar
good to hear it's all sorted mate.. thanks for the info..
see my car here:
[SIGPIC][/SIGPIC]
Old 05-10-2009, 03:18 PM   #8
JMO
JMO's Avatar
Where is the CAM angle sensor located?
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2009, 03:24 PM   #9
Cub35
its located where the Dizzy usually sits. Under the Coils on an AU. Oxygen sensor sounds like the fault with it spluttering etc when cold or it could also be CTS.
Cub35 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2009, 05:14 PM   #10
BillC
Here's the latest. It was not the CAM sensor or the Crankshaft sensor. It turned out to be the alternator. It appears it was only slightly charging and the car when running was sittingf at about 11.5 volts. None of the sensors like that apparently.
Bottom line is new alternator and all is fixed. ...... Till next time.
PS this forum is still playing up for me. It is becomming more frustrating than my car at the moment.
