04-10-2009, 09:08 PM | #1 | ||
Can an au fairlane leather shifter go into an el fairmont ghia??
anybody done this? or offer some advicee? thanks |
04-10-2009, 09:13 PM | #2 | ||
When in doubt, GAS IT!!
If you're talking about just the shifter handle with the spring loaded button then yes it should be a straight swap.
Bushbasher
04-10-2009, 10:07 PM | #3 | ||
ye just the peice u actually grab and the chrome button
have you done this or know 100%? id like to know 100% before i buy it and it doesnt fit if you get me |
04-10-2009, 10:14 PM | #4 | ||
No, it won't fit unless you replace the shifter mechanism as well. E series, AUs and B series all run different style shifters, and changing from one to the other is not that easy, though e series to AU is the easiest - you need the handle and button (obviously) and the shift stalk/frame that bolts to the trans tunnel. Linkages between e series and AUs are nearly identical from the base of the shifter mechanism.
Differences in mechanisms: E series: shifter screws on to the shaft and has a metal actuator rod like X series. AU: shifter slips onto shaft and is held on by one screw and has a plastic actuator rod. B series: shifter screws on to shaft and uses a plastic actuator rod to move a cable, also the button is hinged at the bottom front of the shift handle (A and e series button is spring loaded and side activated).
04-10-2009, 10:15 PM | #5 | ||
positive? is there a thread with a walkthru? i had a quick look but couldnt find? thankss
04-10-2009, 10:17 PM | #6 | ||
Yes, I am positive, though you may need some small mods (cut the trans tunnel) to make the AU one fit, or at least drill some new holes. I have had an EL, an AU and fitted a B series shift handle to the EL and a complete BA shift assembly including cable and SSS electronics to the AU.
