Old 06-10-2009, 10:43 AM   #1
Zedjay
Zedjay's Avatar
Default how do i get the cluster out
how do i remove the dash cluster from an AU3 ???
is it just the two screws at the top and slide it out
or is there more screws?? and ifso where are they??
cheers Rod
Zedjay is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2009, 10:48 AM   #2
T3man
T3man's Avatar
That's it - undo the two screws at top and it just slides out. Try reaching up under the dash to get your fingers on it to give a bit of a push.
Old 06-10-2009, 11:00 AM   #3
Zedjay
Zedjay's Avatar
thanks for that
Old 06-10-2009, 11:10 AM   #4
KR1STO
Just another mock-up..
KR1STO's Avatar
also, be careful of the bottom of the cluster... there's some sticky stuff that sticks it in.....
if you pull too quick you'll tear a little bit of the vinyl and it will annoy you forever..
just go very slowly.. if it's stuck at the bottom, a butter knife is your friend..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2009, 01:17 PM   #5
bartsau
bartsau's Avatar
If it won't budge easily you can stick a big long flat head screwdriver i through the fuse box with the cover off and lever it from behind but you will probably find this easier if you make up a little hook to pull on the top left screw hole.
Good Luck
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2009, 02:42 PM   #6
T3man
T3man's Avatar
I tried the butter knife once - got the irrits totally with the yellow slimey residue it left behind and it annoyed me forever. LOL.
Old 06-10-2009, 05:12 PM   #7
Halfmo Rocks
Bearded Hermit
i find getting the thumbs into it works pretty well...little outward push on each side with the thumbs as you pull & it just slides out
Halfmo Rocks is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2009, 07:16 PM   #8
51OAU
51OAU's Avatar
how easy it to remove the glass from these?
51OAU is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2009, 07:31 PM   #9
KR1STO
KR1STO's Avatar
you have to separate the tabs.. it's quite easy to do, but, take your time cos they break easy..
once the cluster is out, you'll understand this post...
see my car here:
[SIGPIC][/SIGPIC]
Old 06-10-2009, 07:35 PM   #10
aye you
The Origional, The Best
aye you's Avatar
in regards to sliding out the cluster, i had a suction mount for a camera that i attached to the cluster and it just pulled out. so find yourself something with a suction cap on it. makes life a whole lot easier
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2009, 08:26 PM   #11
51OAU
51OAU's Avatar
can u buy the tabs?
Old 06-10-2009, 08:56 PM   #12
ronwest
All Bran = Regular Member
Originally Posted by 51OAU
can u buy the tabs?
They're part of the cluster body.
The tabs can be repaired with contact adhesive (this from personal experience)
edit: should explain that you'll only break one or two of the tabs. By that stage you'll have figured out that you need to go a bit easier on them, lol.
Old 06-10-2009, 08:58 PM   #13
KR1STO
KR1STO's Avatar
yeah as ron said.. they're part of the cluster...
if you take your time, it can be done..
see my car here:
[SIGPIC][/SIGPIC]
Old 07-10-2009, 08:02 PM   #14
Halfmo Rocks
Bearded Hermit
but when you break them...it just makes it easier to get the cluster out next time...i know
