Old 13-10-2009, 09:21 AM   #1
deathlucky
Awesome Member
deathlucky's Avatar
Default was a detroit locker even an option in xg and xh utes
i have been told to put a detroit locker out of an xg or xh in my eb2 question is did they ever have 1 in them from factory? and what are the advantages over a detroit locker and a lsd
17" BA XR8 Copies, Pedders Coilovers Front & Rear, 30mm Front 24mm Rear Whiteline Sway Bar, Strut Brace, Camber Kit, Slotted Front Rotors, 1636 Wadecam, Au Injectors, El Ecu, TurboSmart FPR-800 (275kpa), MSD Street Fire Ignition, MSD High Vibration Blaster Coil, Pacemaker 4499, High Flow Cat, 2.5" Sports Exhaust, Twin Pod Filters, El Thermo Fans, 2 Stage Shift Kit, Pioneer Sound System : 123.3RWKW
deathlucky is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 09:52 AM   #2
smally289
growing up is optional
smally289's Avatar
No detroit lockers from factory in those. Only 'Hydratak' diffs in the outback models. EL GT's and some HSV Dunnydoors also use the Hydratrak centre. Google it and read up if you want more info.
I have to ask why you have been told to put a Detroit Locker in? What sort of driving do you do?
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 11:44 AM   #3
deathlucky
Awesome Member
deathlucky's Avatar
ok then thanks for the help i was saying to a mate the next thing i need to do to the car is put an lsd in and he started saying to put a locker in i didnt ask why
Old 13-10-2009, 11:48 AM   #4
V3RSAC3
... Fear it!
V3RSAC3's Avatar
Mine had LSD.? But I don't think they did from factory. :S
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 12:04 PM   #5
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Yep the Hydratrak are a viscous coupling LSD. They will be hard to find and I did read on here that they are no longer available and cannot be serviced/rebuilt due to being a sealed unit - an issue with BTR or whatever their name is these days! Once the viscous fluid inside has degraded or been cooked there is a problem.
Deathlucky I'm sure wikipedia will have a description on how a detroit locker works compared to a normal clutch-pack LSD, there are also a few other types available now. I wouldn't have a detroit locker as a first choice for a street car.
