Old 30-10-2009, 05:25 PM   #1
chevypower
chevypower's Avatar
Default More on EcoBoost 3.5 for RWD application
Just saw this link on pickuptrucks.com.
http://jalopnik.com/5392757/400-hp-e...d-hitting-sema
It's the first time we can see how much power and torque this engine will have in RWD applications (possibilities would be F150, Expedition, Mustang and Falcon) to put out approximately 400HP/400lb-ft. (300kw/540Nm). Remember that that torque will be available from under 1800rpm up to around 5000 rpm, no lag, gets the fuel economy of a standard 3.5 V6, and runs on regular unleaded. Oh and it's obviously designed to be strong enough for towing.
Nice hot rod too!
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2009, 08:02 PM   #2
Deco28
There is no way it would have the same fuel economy of a N/A 3.5l V6, I'd say you're mistaken on that commen. It would however offer V8 performance for less economy.
Deco28 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2009, 04:09 AM   #3
chevypower
chevypower's Avatar
Well if it had "less economy" than a V8, that would defeat the purpose. I assume you mean "better economy" or "less consumption." Anyway, Ford says the EcoBoost engines have the same consumption as the N/A engines they are based on. If you look at the Flex and Taurus N/A AWD 3.5L V6 versions and compare them to their EcoBoost counterparts, which also have a 3.5L engine and AWD, they have the same fuel consumption. That is the only evidence we have at the moment, so anything to the contrary is just speculation.
Old 31-10-2009, 11:38 AM   #4
EDManual
EDManual's Avatar
What it will do is have pretty much the same economy HP for HP. That is if you need to use 300hp you will use 30 litres per hundred in a v8 or this v6.
When you dont need all the power it will use less as it has lots of low torque for normal driving.
Thats what I think anyway..
EDManual is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2009, 01:02 PM   #5
Chilliman
Chilliman's Avatar
How do you explain the XR6 Turbo then? Same power as the 6.0Litre Commodore, but uses over 2Litres/100Km less......and out guns its - 0-100Km/hr and 0-400metres
From www.motortrend.com
"Torque is the new horsepower"
Chilliman is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2009, 01:25 PM   #6
FordFalconBF
2008 BF Futura
FordFalconBF's Avatar
That's because traditionally Holden has always needed to have higher ltr v8 motor produce the same power Ford has with it's smaller ltr sixes and eights. Holden will probably bring out a 25ltr v8 next to beat the 5.4 of Fords. My little rant.
2008 BF Falcon Futura
2009 BF Falcon Wagon Dedicated LPG
Previous Cars:
2003 BA Falcon Wagon Dedicated LPG
1999 Ford Fairlane Ghia
XF Fairmont Ghia
Escort MK2 RS2000 Replica
FordFalconBF is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2009, 02:51 PM   #7
Falc'man
You dig, we stick!
Falc'man's Avatar
You need to account for the mass of the vehicle.
If the n/a 3.5 is struggling to pull 2t then it wouldn't surprise me at all if the turbo had better or the same consumption, especially when torque is peaking at 1800rpm.
As you already know, the seedy 3.0 isn't more economical than it's bigger, more powerful 3.6 litre sister, as has Holden forgot the VE wasn't exactly a flyweight.
A car's mass needs to be matched by the right amount of torque at the right amount of rpm, to meet it's objective.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2009, 05:08 PM   #8
EDManual
EDManual's Avatar
well when its not using its power its more economical because of the easy torque at low revs, but when it is using it its probably about the same.
It gives you the choice.
Turbos use heaps of fuel if floored. Thats a fact...
Old 31-10-2009, 05:25 PM   #9
chevypower
chevypower's Avatar
As does any engine, I guess the nice thing about the EcoBoost is it has the low end torque of a diesel, not a wimpy low-end that we are used to with most turbos. The type that you have to floor it just to enjoy it. But if you do open it up, it has it there also... I am really liking the idea of this engine.
Old 31-10-2009, 06:53 PM   #10
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Correct. But thats not to say that in spirited driving mode the i6T uses more fuel than the outdated, but reasonably effective (if poor for emissions-hello soon to be EuroIV-crippled performance) GMH 6.0L.
Most tuners agree that a well sorted NA uses fuel, has a BSFC of about 0.5lbs/hp/hr. A turbo has about 0.55-0.60 lbs/hp/hr. With the i6T at the lower end of that from most reports.
But the other 85% of time when your not on it. The i6T benefits from being 33% smaller. Much lower pumping losses.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
