Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 06-11-2009, 05:29 PM   #1
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Super Specials November Only
I decided to list some super specials for November instead of a group buy so we can supply for a wider variety of car model.I will list everything we are doing but there will be many an item not listed so please do not hesitate to contact me.I will list some conditions though to retain the cheaper prices and these will be at the bottom of the list.Some part numbers we will have many of but some parts are limited so first in first served sorry.Please do not hesitate to ask me any questions for correct fitment
3 BUMPER SPECIALS
1.Brembo 6P355mm /4P330mm brake upgrade combo for FG with DBA4000 series slotted rotors $4850
2.Ferodo DS Performance in DB1473 shape only $175 a set - normally these are $220 and suit BA,BF,FG and Territory front
3.Ferodo Formula brake pads to suit the front only C5 Premium brake upgrade on the BA (Bendix no 7599) Blue caliper for $90 a set.All other part numbers are $115 a set as listed below
BRAKE PAD
TRW Ceramic brake pads are low dust and low noise at $55 a set - street
Ferodo TQ Thermo Quiet street pads low dust and low noise at $55 a set - street
Ferodo Formula performance brake pads all are $115 a set - performance
DBA SLOTTED ROTORS
DBA 500 SL/SR AU1 front slotted rotors $95 each
DBA 501 SL/SR AU1 rear slotted rotors $105 each
DBA 502 SL/SR AU11 front slotted rotors $95 each
DBA 503 SL/SR AU11 rear slotted rotors $105 each
DBA 504 SL/SR BA BF front 298mm slotted rotors $95 each
DBA 505 SL/SR BA BF FG rear 303mm solid slotted rotors $95 each
DBA 4504 SL/SR BA BF front 298mm slotted rotors $140 each
DBA 4505 SL/SR BA BF FG rear 303mm solid slotted rotors $140 each
DBA 42107SL/SR front 322mm slotted rotor
BF XR6T XR8 FG and Territory @ $215 each
DBA 42108SL/SR rear 328mm vented/slotted rotor
BF XR6T XR8 and Territory @ $200 each
DBA 42102SL/SR 355mm front slotted $280 each
AU111 BA BF FG Tickford Pursuit FPV GT etc with Brembo 6P or 4P calipers
DBA 4507A/B SL/SR 330mm rear slotted $215 each
AU111 BA BF FG Tickford Pursuit FPV GT etc with Brembo 4P calipers
DBA 42108SL/SR rear 328mm vented/slotted rotor @ $200 each
BF FG Tornado Pursuit FPV Tickford with single piston PBR caliper
If your model is not listed please contact me and i will see what i can do for you thankyou.
Please read conditions.
1.First in first served with goods as we have limited supply on some numbers.
2.Unless items are sold out we will run specials until end of November and that is final.
3.All items need to be paid for in full before we freight.
4.Pick up is available and payment by credit card or eftpos on pick up only is fine.
5.We will not be able to hold some items for customers so please contact me first.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 07-11-2009, 04:19 PM   #2
BomberXR
BomberXR's Avatar
Any chance of a price for the DBA 4504SL/SR and DBA 4505SL/SR for a BF II XR6 sedan N/A please Matt? I have to ask a dumb question as well, why are the front discs smaller in diameter than the rears on the non turbo's? (298mm compared to 303mm). Also what pads do you recommend to go with the above discs, currently use the TRW pads on my XR ute with slotted RDA's.
Cheers,
Nigel
BomberXR is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2009, 07:25 AM   #3
dddp
dddp's Avatar
at a guess it's because the non turbos have smaller front rotors than the turbos - the rears are large because of the hand brake drum in the centre
dddp is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2009, 04:39 PM   #4
BomberXR
BomberXR's Avatar
yeah I saw that when looking at the turbo disc sizes but I thought seeing that you do most of your braking with your fronts what was the reason/logic??? : thanks for that.
Old 09-11-2009, 09:56 AM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Cheers,
Nigel
The rotors are $140 each and i have now listed them on the specials list.
The rear rotors are bigger in most BF turbo and XR8 models as well with a 322mm front and 328mm rear but we have now found some late versions of these along with the FG now runs the 322mm front and the same BA 303mm solid rear which i think is for cost cutting.I don't think you they have bigger rears because of the handbrake as the AU11 and 111 only had 287mm rear discs with the same handbrake and I would like to think the larger rears were to get some better braking out of the back brakes.
If you are using the car for std street driving then either street pad works well in these cars but if you drive the car hard then the performance pads are the way to go but you can run front DS performance and street rear if you wish.
MATTHEW PEARCE
Phone 02 9609 1101
Old 09-11-2009, 12:24 PM   #6
BomberXR
BomberXR's Avatar
thanks for that matt, whats the approx postage costs to 3438 with 4 x rotors and pads please
Old 09-11-2009, 02:49 PM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
About $45 thanks as it is nearly 40kgs.If Melbourne have the rotors in stock at the time of ordering we can send direct from them and the pads from us to see if that reduces the freight cost.
FYI - If anyone is interested we can organize pick ups from Sydney,Melbourne,Brisbane and in some cases WA as long as stock is available and full payment is made.Brake pads will still have to be freighted.
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-11-2009, 10:50 AM   #8
04BAsed
MR39PT
04BAsed's Avatar
Hey Matt.
Can u give me a price Inc. Postage to 2756 for front n back slotted rotors, and pads to suit for a 04 ba futura sedan.
Cheers Dave
LONG list of up n coming mods for the BA FUTURA
Bseries.com.au/04BAsed
04BAsed is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2009, 12:04 PM   #9
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by 04BAsed
Hey Matt.
Cheers Dave
Dave PM sent
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-11-2009, 12:23 PM   #10
Suvo
BA Fairmont Ghia X
Suvo's Avatar
Hey Matt,
Just wondering on the price of front and back slotted rotors and pads for an 02 BA Ghia + postage to 3757
The Cars
2020 PX 3 Ranger Wildtrak, 3.2 Manual (Wifes)
2014 FGX XR8 - Silhouette, Manual (Fun)
2002 BA Fairmont GHIA X, Now 230kw 3V V8 + ZF 6sp (Semi retired)
1994 Land Rover Discovery 1 3.9 Manual (Bush hack)
1992 DC LTD, 5L (Daily)
1979 ZJ Fairlane, Sno White (Gone but not forgotten)
1979 P6 LTD Town Car, Clevo goodness
Suvo is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2009, 12:57 AM   #11
mattp
mattp's Avatar
Hey mate, I'm after new rotors and pads for the rear of my BA GT-P, with 4P Brembos.
I've got 5000 series rotors on the front, is the 4000 series the best I can do for the rear? I also need pads, and would appreciate your advice on the best ones to match up to the rotors. I do only street driving, no trackwork and don't drive particularly hard but want something decent.
Are the 4000s the ones with the gold hubs? I want something that won't rust on the hubs if possible, and the fronts I have are the gold aluminium hubs.
I can pick up in Brisbane if possible, or please quote postage to 4007.
Thanks a lot mate,
Matt.
Are these the ones I need 'DBA 4507A/B SL/SR 330mm rear slotted $215 each'? thanks.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2009, 01:14 PM   #12
FTe_XR8
formerly "3x-puursui7"
do you stock the DBA 506's? these are the front discs for AUII+ with premium brakes and they were a real PITA to get cos everyone kept selling me the 502 and 504's.
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2009, 11:12 AM   #13
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by Suvo
Hey Matt,
PM Sent
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-11-2009, 11:28 AM   #14
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks a lot mate,
Matt.
The 4000XS have the gold hubs and are $250 each but the ones on special are the slotted with a gunmetal grey hat.We have the Ferodo Formula pads on special in the rears for $115 a set thanks or we have other pads from $198 (less dusty) thankyou.
Stock of the slotted 4000 rotors is available at the moment so you can pick up but pads will have to be freighted at $12 thankyou
FTe_XR8
Yeah i have alot of people tell me that.I can get the DBA4000 series slotted for you and are $340each this month.If you want just plain rotors i can get them in a generic brand for $115 each.
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-11-2009, 11:19 AM   #15
PSI-54L
PSI-54L's Avatar
HI Matt,
Im due for Brakes on my BF1 XR6 Turbo ute.
( I believe series 1 have the territory brakes ? )
Anyway, im reasonably happy with the performance of the factory set-up, however wouldnt mind a slotted rotor on the front.
Could you price me up for;
- 4 Rotors to suit ( Front slotted )
- Front & Rear Performance pads low dust
Will be pick up from you @ Wetherill Park.
Cheers,
Chad.
Chad.
Supercharged XR8
HSV
CVO Breakout
PSI-54L is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2009, 11:54 AM   #16
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by PSI-54L
HI Matt,
Cheers,
Chad.
Chad i have quoted you with rear slotted as well but there are no performance pads that are low dust sorry so you will have to go one or the other but if you are happy with the std factory brakes then the street low dust should be fine but the rear pad that suits the larger 328mm disc is still not made in the low dust brake pads that we are offering but can be purchased in the Bendix GCT compound for $70.
DBA 42107SL/SR front 322mm slotted rotor @ $215 each x 2 = $430
DBA 42108SL/SR rear 328mm vented/slotted rotor @ $200 each x 2 = $400
All rotors are $830 plus whatever pads you decide.
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-11-2009, 11:56 AM   #17
Fev
Fev's Avatar
Hey mate,
Just wondering what sort of price would you give to replace the discs on a 2003 BA XR6T with the premium brake upgrade? The normal discs are the 325mm(?) swirly slotted discs.
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2009, 12:09 PM   #18
PSI-54L
PSI-54L's Avatar
Thanks for the response.
What pads would you reccomend for " Street " / " Low Dust " ?
Prices?
Chad.
Supercharged XR8
HSV
CVO Breakout
Old 17-11-2009, 12:44 PM   #19
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Originally Posted by Fev
Hey mate,
+1.. Also Interested in these
Also are the pads listed here, good Weekender/spirited driving pads?
Would need Pads Front & Rear.
FPV8U is online now   Reply With Quote Multi-Quote with this Post
Old 17-11-2009, 01:23 PM   #20
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Fev Hey mate,
These 325mm performance upgrade rotors were not listed at the time because they had no stock but we can now get them done in the 4000 slotted which will be 1 week from order and will cost $231 each.The rear rotors are just the solid 303mm and are $95ea for street series slotted or $140each for the matching 4000 series slotted.
Yes the pads are good for that kind of driving.As above for the rotors thanks and yes they are the correct pads for the Premium upgrade front for $90 and the rear ones in the same material are $115 a set thanks.
PSI-54L
Prices?
The only rear pad available in a low dust style to suit the vented rear disc is a bendix GCT pad which are $70 and you could run the TRW ceramic in the front for $55.Just check and confirm your rear disc is either 328mm vented or 303mm solid as this will determine the pads you can use in the rear.
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-11-2009, 02:57 PM   #21
FPV8U
FPV8U's Avatar
Thanks mate, if i can get the fincials in orfer i'll be in touch at the very least in regards to the F & R brake pads before the end of the month.
Old 17-11-2009, 03:59 PM   #22
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No worries
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-11-2009, 04:34 PM   #23
Fev
Fev's Avatar
Thanks Matt. I'll see what my father wants to do. He's gotta replace his soon.
guys, just remember to get the right pads - I chose the Bendix GCT's to go with the DBA4000's and because of the resin content or something they heat up too much and warp - It's not huge bad warp, only gets bad when they really heat up.
There's a few threads about it somewhere
Insta@mooneye_ghia
Old 17-11-2009, 05:17 PM   #24
Noddy
Mercury Silver T3
Noddy's Avatar
Whats the part no of the slotted front disc on the premium brake option on the auiii xr8?
House of Tickford
T3 TS50 No.156
AUIII XR8 220
2017 Magnetic Mustang
What to hear a tuff T3?
Click here
http://s7.photobucket.com/albums/y30...ent=Movie2.mp4
Noddy is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2009, 01:52 PM   #25
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Should be DBA506 330mm x 28mm and i think it is the C4 caliper which was grey and has two holes for the pad to locate on.
MATTHEW PEARCE
Phone 02 9609 1101
Old 20-11-2009, 11:50 PM   #26
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
track day pads for E series ??
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2009, 05:14 PM   #27
tickford2001
Hi Matt,
DBA 4046BSL & 4046BSR ?
Also, the rotors on their own (no hat) if possible?
Thanks
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2009, 05:43 PM   #28
tickford2001
sorry, read the wrong box! 5046.1 SL & 5046.1 SR are the numbers i meant (price with and without hats if possible thanks)
Old 25-11-2009, 12:07 AM   #29
342PURSUIT
342PURSUIT's Avatar
BRAKE PAD
Hey matt
Can i get any of these for for the 4pot brembo's front
T3
TS50, PURSUIT250
Both in blueprint
342PURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2009, 11:07 AM   #30
FLOORED
Race Brakes Sydney
FLOORED's Avatar
DBA5046B BLK SL/SR - The B on the end of the number is the conversion rotor and without the B is the factory size rotor and either will cost $500 each
The replacement rotors are correct 5046.1 SL & 5046.1 SR and these are $300 each thankyou
MATTHEW PEARCE
Phone 02 9609 1101
