Chairman & Administrator
![]() ![]() Join Date: Dec 2004
Those who read MOTOR (or the thread here) know that they recently conducted a test involving 22 after market tuned cars which was won by a number of mega expensive cars that had been made even more so by the fettling they had received. They had also used their own BFYB formula to award the Evolve VW Polo GT that crown.
I thought it might not be a bad idea to look at two of the criteria they used - dyno power and400m times as a guide to applying some different math and see what we came up with. Methodology 1. The MOTOR figures for rwkw and 0-400m times have been used. 2. The factory figures for fwkw and 0-400m times from the MOTOR guide page have been used as baseline figures. The fwkw numbers have been multiplied by 0.7 to arrive at an approximate rwkw figure for the factory numbers. 3. The performance based costs have been used - including all engine and driveline modifications but excluding wheels, tyres, brakes and other handling oriented items. 4. Cars that cost more than $110,000 in base form have been eliminated. Dyno Results Here we are looking at the cost per rwkw gained as an indication of where the most bang for the $$ involved has come from. Using this criteria, the winner is the Herrod modified G6ET which leads the field with a cost of $51.34 per kw gained. ![]() 0-400m Results Similar math is applied here to establish the cost for each 1/10th second gain given that we know how expensive chasing those extra tenths can be. Again the Herrod modified G6ET proves itself a value proposition with a cost of $398.40 for each 1/10th gained and the remaining order unchanged from the table above. ![]() Overall Value For this we have used to different sets of criteria (as above) but with the total cost of the car taken into consideration. The first table looks at the total cost per rwkw where the Herrod XR8 Ute takes the crown with a cost of $192.18 per kw ahead of the Herrod G6ET and Commodore SS-V sedan - testament to the value the base vehicles provide in the first place. ![]() The second table looks at the total cost per 1/10th of a second - here the order is turned around to favour the more expensive base cars with the City Performance Golf R32 (which turned in an 11.99) taking the win ahead of the two BMW 335i's entered. ![]() Braking Some of the packages provided big dollar brake upgrades and it seemed like a good idea to see how these shaped up. The table below uses an index based on the vehicle factory weight, the braking distance and the cost of the brake package. As you'd expect it's not very definitive and it tends to favour the lighter cars (where the $ spent can provide a greater gain) but it does highlight the relatively poor performance from the KPM big brake upgrade on the SS-V as it needed 5m more to stop than the similarly equipped VCM SS-V for half the brake cost. Likewise it proves that there is no substitute for light weight and big brakes as the shortest stopping distance went to the 1239 kg Polo which was equipped with 350mm front and rear rotors! That it stopped nearly 8 metres quicker than the worst of this bunch is a scary thought. ![]() Cheers Russ
Observatio Facta Rotae
Oo\===/oO
Very interesting, the G6E versions are working wonders in comparos
![]() What was done to the lancer?
Regular Schmuck
Interesting numbers.
Did Herrod give a reason why they went the G6ET route and not the XR6T? 97kw for ~$5000? I'll take 3, thanks. |
The Lancer copped an ECU tune and exhaust.
I suspect Rob went the G6ET as it is his daily driver! Cheers Russ
#5 | |||
IWCMOGTVM Club Supporter
I've seen his G6ET, bloody nice. Good to see Herrod making good inroads with the I6T and the 8.
Daniel |
The 'Stihl' Man
![]() Join Date: Jan 2005
Ah an R32 running 11.99 1/4's, holy hell!
What issue of MOTOR was this?
#7 | |||
2015 PX2 Ranger xlt dual cab manual tech pack cool white, 2012 FG2 XR6 turbo limited edition kinetic |
Shame Holden, Shame
Russ, you say that G6ET had 189RWKW but we know from members that it has around 230-240RWKW from factory, so perhaps not such an impressive gain?
Essendon FC '11 EFII "XR8" Fairmont V8 185KW ELII XR8 engine, box & exhaust|Dual Fuel|Tints|FTR's|Factory bodykit |K&N panel filter|Interior LED Conversion|Leather steering wheel|Slotted rotors|Ghia wood + chrome|Subwoofer| ![]() ![]() |
Member
This doesn't add up right to me. Looks like they've just taken 30% off the engine power figures to calculate rwkw. 189rwkw for G6ET? They dyno well over that. So, if I'm correct (correct me if I'm not), this throws out the whole basis of the $/kw comparison does it not?
#10 | |||
The 'Stihl' Man
$50 odd k on mods to a hatch! A total of $100k spent on a Golf..that is madness.
#11 | ||||
Shame Holden, Shame
The message you have entered is too short. Please lengthen your message to at least 5 characters.
#12 | |||
Bolt Nerd
To start with a level playing field, what else can they go by then the manufacturers quoted Kw -30%?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner ![]() |
Member
Regardless of where the figures came from, they are too low. If you are starting from an understated rwkw figure, the $ price per gained kw is going to understated as well. Although to be fair, the 30% rule looks like it has been used throughout, so the rankings would be about right, but I can't agree with the exact dollar figures, ie, $51 per extra kw for the G6ET.
#14 | |||
The "they" you refer to is me. As noted in the original post all of the factory fwkw figures have had 30% removed to account for driveline losses so that they can be compared with the dyno numbers. This doesn't invalidate the results as whatever factor you applied the order would remain the same - what would change (naturally) is the cost per kw gained. Those who don't like the chosen percentage can simply apply their own but I had to choose an arbitrary figure and did so. If you apply 20% to the G6ET (for example) it ups the cost to $71 per kw gained but given we were after the order and not the actual figure it hardly matters. A G6ET with only a 15% drive line loss (to return 230rwkw) is clearly incorrect but then without the benefit of before and after dyno results on the same car there isn't exactly much else we can do is there? The raw data is there for anyone to use so if you reckon there's a better way then be my guest. Russ
#15 | |||
Chasing a FORD project!
G6Et did very well but I agree; we have seen these cars in stock form punch numbers well over 189rwkw standard. Stock fwkw they claim 270 so going by the numbers here that's a loss of almost 100kw(ok 81
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon. |
#16 | |||
By the time I wrote that, there where two more replies in regards to what I and others had written. Therefore disregard.
#17 | |||
![]() Russ
#18 | ||
Member
Thanks for the clarification Russ. At the end of the day, 30% might be accurate for some engines but not others. I've never heard of an FG turbo punching out below 220rwkw, but at the same time WRXs in general might consistently dyno with around a 20-30% drivetrain loss.. so for a more accurate dollar figure as well as list, you'd need to apply what the stock vehicles dyno on average in the real world because deviation from stock is what we are measuring, so the stock figure is obviously very important. Assuming that every motor will lose the same proportion of power from engine to rear wheels on a dyno is my criticism.
#19 | ||||
#20 | |||
Anyway, for the sake of the exercise I have gathered a range of real world dyno figures on stock vehicles in the list and averaged them to arrive at the numbers in the table below. ![]() As a matter of interest the drive line losses range between 14.81% (for the obviously understated G6ET) through to 30.33% for the Mazda RX8 with an average a fraction over 20% - a figure I used in the second version above and which I shall probably treat as my new baseline. Cheers Russ
#21 | |||
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
#22 | ||
Thats what it says...
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
#23 | ||
Broken
Please correct me if I'm wrong, but aren't the 'performance' costs quoted inclusive of body kits, wheels, tires, brakes, suspension for some of these vehicles?
If that is indeed the case, for complete parity, shouldn't we be looking at engine only modification costs...? Unless Ive missed something? Interesting comparo none the less.
The Scud GT 11.4 @ 128, 1.88 60ft. |
#24 | |||
Member
#25 | |||
3. The performance based costs have been used - including all engine and driveline modifications but excluding wheels, tyres, brakes and other handling oriented items. Cheers Russ
#26 | ||
Oo\===/oO
fwkw into rwkw figures is always gonna cause some sort of discussion.
#27 | ||
You dig, we stick!
Thanks Russell, quite good to read through.
I'm guessing, in about 6 years time, a whole chunk of 20 y.o. motoring enthusiasts having only one car on their minds.
"....You don't put the car through engineering" - Rod Barrett. |
#28 | |||
Meep Meep
People keep saying that as though its a bad thing. Demand=$$$$ and if rabble want turbo Barra goodness it can only mean an increase in resale prices.
Thundering on.... |
#29 | ||
Half an aussie garage!!
What did the 50K on the commodore buy them if it only ran a 13.09?
#30 | |||
It is interesting to note how the G6ET has become the "darling" of the performance mod crowd when the XR6T has exactly the same engine and transmission, costs less and weighs slightly less. Must be because it is a new model....... |
