Old 22-01-2010, 09:28 AM   #1
sd1800
Default Slight Front End Knocking / Tapping
Hoping someone may have come across this before and would be able to point me in the right direction. I have noticed recently that I am getting a distinct yet subtle knocking/tapping from my front end when going over even small bumps in the road. I can really only feel it through the footrest since that isn't insulated by carpet and is bolted straight into the chassis? Any idea what it may be?
On a side note, the front end has also started occasionaly clunking when I do a hard right turn or do a slower U-turn but close to full lock. Common problem? Any ideas?
Car has 108000km but not entirely sure what has been changed in the past as I've only had it for a few months. I have put a recond steering rack about 3 months ago however.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 09:42 AM   #2
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
I had that. It was my swaybar. Right at the end there's an eye that bolts to the link thingy. The nut can work loose.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 09:44 AM   #3
sd1800
Thanks.
Is that the clunk or the vibrations?
Now......
- 302rwkw
2019 Escape St-Line
Old 22-01-2010, 09:58 AM   #4
lofty
Rusticating
lofty's Avatar
Sorry, that was the clunkety-clunk on low speed bumps.
Old 22-01-2010, 10:50 AM   #5
sd1800
Cheers, I'll jack it up and have a look over the weekend.
Anyone got any ideas about the clunk coming from front left wheel when turning right?
Now......
- 302rwkw
2019 Escape St-Line
Old 22-01-2010, 11:10 AM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Ball Joints Brother!
Old 22-01-2010, 11:52 AM   #7
sd1800
Yeah I had the ball joints checked about 3 months back and they were fine(the problem was the rack) however I guess alot can happen in 5000kms. I'll give it another look. Thanks for the advice boys. I'll keep the thread updated if I find out what it is.
Now......
- 302rwkw
2019 Escape St-Line
Old 22-01-2010, 11:57 AM   #8
Mr Hardware
about 3 months back and they were fine however I guess alot can happen in 5000kms
Sure can buddy. AU ball joints are notorious for being fine one day, buggered the next. And make sure they check upper and lower ball joints.
Old 21-03-2010, 06:44 PM   #9
sd1800
Thought I would be best updating this for future notice. The knocking on the footrest was a rooted swaybar rubber.
However the clunk is still there. I asked him to look over the front end of anything else that would be causing the clunk and he couldn't find anything other than the swaybar.
Mr Hardware, would it not be common practice to check the UPPER ball joint?
Now......
- 302rwkw
2019 Escape St-Line
Old 21-03-2010, 08:34 PM   #10
bodes-sh
i'd say ball joints too. i get clunking in the front under brakes when turning, it's fine when not on the brakes. it is a lot less now with 17's on it, but still does it. the ball joints on mine look pretty average, but i haven't got around to getting them done yet...
Old 21-03-2010, 09:12 PM   #11
sd1800
Thing is I had my mechanic go over the obvious like ball joints, rubbers e.t.c. (he found the issue with swaybar rubber). He said everything else was fine so the only thing I can think of is perhaps he didn't look at upper ball joints as it's usually the lower that fail, isn't it?
Also, theres no play in the front wheels when it's jacked up.
EDIT: To clear up any confusion the issue that remains is:
"On a side note, the front end has also started occasionaly clunking when I do a hard right turn or do a slower U-turn but close to full lock."
However since I posted that back in Jan, over time I have gotten used to when it will do it. I can guarentee if the car has been sitting for >2hours as soon as I jump in and do a low speed right turn it will clunk. From there on it will only do it on the rare occasion until I park the car for another few hours at which time it will do it again. It also DOESN"T have to be full lock like I thought previously, it can just be a slight right turn but always at low speed.
Now......
- 302rwkw
2019 Escape St-Line
Old 21-03-2010, 09:54 PM   #12
Whoosha
AU DIE HARD
Whoosha's Avatar
Top ball joints clunked from new they had a recall on them on early S2s,(bodge grease or something like it ) very hard to pick just with normal inspection. bottom joints just tended to fall out and chew your rotor up :
Originally Posted by Riksta
Old 21-03-2010, 11:28 PM   #13
frd906
what about the top control arms bushes, ??
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2010, 11:20 AM   #14
xrford
WAGONE
xrford's Avatar
did you definately replace the swaybar links? mines been clunking away for quite a while now, ordered the nolethane links just waiting for them to come in.
You may not think therye rooted from visual inspection but id be replacing them first then see what happens
$50 on ebay or try your local parts supplier
http://cgi.ebay.com.au/2-Front-Sway-...item27ad454cd7
xrford is offline   Reply With Quote Multi-Quote with this Post
