Old 22-01-2010, 09:12 PM   #1
SSD-85
Default XR8 Auto problem
Good evening all,
This afternoon my Xr8s' automatic transmission, holds 1st until 2k rpm or 3k rpm depending on how quickly its accelerated. It will not shift beyond 2nd. And once i release the throttle is seems to go into neutral as it rpm drops to idle speed (just under 1k rpm). Diagnosis?
PS: ECU has been reset to no effect.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 11:50 PM   #2
frd906
Low gear box oil ?
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 12:08 AM   #3
GK
Walking with God
GK's Avatar
Originally Posted by frd906
Low gear box oil ?
That would be the first thing I'd check as well.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 23-01-2010, 01:56 PM   #4
SSD-85
How do I go about this given theres no dipstick?
Old 23-01-2010, 01:59 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Now this is a bit trickier. There's a fill hole on the front of the box (drivers side). Top it up with TQ95/95LE until it starts to spill out. I *think*.
Old 23-01-2010, 02:02 PM   #6
SSD-85
Well i wont mess with it until i know for sure. Since if it is as something as simple as low fluid then ill be stoked.
Old 23-01-2010, 02:08 PM   #7
frd906
i wouldnt be driving it either, untill you check the oil,
Grab a funnel and a long bit of 10mm hose, undo the nut on the drivers side of the gear box, make sure you have a bucket underneath where the fill point is, unless you want it spilt everywhere, shove the hose into the fill hole, then feed the hose to the outside of the car, stick the funnel into the other end of the hose and slowly poor the fluid down untill it starts to over flow out,
also forgot to mention, will be easier using ramps or a low spot, to get under the car
Old 23-01-2010, 02:25 PM   #8
SSD-85
Although I would be suprised if it is low fluid, given that there is no leakage, or signs of it anywhere. Also it happened rather abruptly, shifts were fine only 10mins before I got back in and started it back up.
Old 23-01-2010, 02:37 PM   #9
Mr Hardware
Well when last year did you have your trans serviced?
Old 23-01-2010, 02:39 PM   #10
SSD-85
I havent, I only bought it 6 months ago. Yes, I know I shouldve got it done. But time and money saw things differently....
Old 25-01-2010, 12:12 PM   #11
sd1800
To back up everyone else here I did have a similar problem when I bought mine where it would slip into neutral, usually on cold mornings, and it turned out to be low fluid. Had it filled up and it hasn't done it a single time since. I didn't have any external leaks either.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2010, 12:24 PM   #12
Mr Hardware
Well scotty i'd be getting it serviced asap. Yes it could have only been serviced 7 months ago and it also could have been serviced never. It's $120 or so, get it done.
Old 25-01-2010, 12:29 PM   #13
RG
Back to Le Frenchy
RG's Avatar
Best post this bloke has ever made.
Agreed, it's a 5 minute job so give it a go. You'll either need a decent length spanner or a extension for your ratchet as the exhaust can be a bit tricky to get around.
Old 25-01-2010, 12:56 PM   #14
frd906
thanks RG, when i got mine done, was about 150 bucks for a service, after i got mine down, gear seemed to repsond a hell of a lot better to the foot,
Old 25-01-2010, 04:28 PM   #15
SSD-85
Ok, took it in. Its lost the bands for 2nd and 4th, also engine braking clutch. It is being pulled apart as we speak, but its looking like a rebuild. :(
Old 25-01-2010, 05:22 PM   #16
Mr Hardware
ooh, sadface scotty.
Old 25-01-2010, 06:00 PM   #17
SSD-85
: . Nah its all good. you live and you learn.
Old 25-01-2010, 07:00 PM   #18
InfernoSR
Sales Representative
InfernoSR's Avatar
atleast you have an answer... take that as a positive...
Old 25-01-2010, 08:06 PM   #19
Beer Baron
Whats the rebuild worth if you don't mind me asking ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2010, 08:34 PM   #20
SSD-85
^^ seems to generally be around 2 grand. prices dont seem to variate that much.
