Old 28-01-2010, 06:11 AM   #1
BA SR FALCON
BA SR FALCON's Avatar
Default What Moter To Use ?
What is a strong 4 cyl like pinto but newer, hi tec ? cant be a east west moter, turbo would be ok computer inj Whats the ford equlivent to a rb30?
, this would be used with tran's to re power my 59 van.. any thoughts apart from cortina [to old] :
BA SR FALCON is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 06:27 AM   #2
banarcus
hmm eyebrows
banarcus's Avatar
Silvertop or blacktop ZETEC motors 1.8L or 2.0L. Google "escort zetec" and go through the results. Can be adapted for RWD.
XE 4.9 Falcon S & XA 4.9 Fairmont hardtop
banarcus is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 06:37 AM   #3
BA SR FALCON
Default Will look
Thanks ... if u run a air con + p/s will that make them a bit gutless or being hi-tec do they cope.. i am used to old school ! Cheers
Old 28-01-2010, 08:32 AM   #4
cosmo20btt
Fordaholic
cosmo20btt's Avatar
I am not a Nissan fan but a good versatile motor to use is the sr20de or sr2odet lots of parts are available for these.
I know it's not Ford but Cosworths are like gold these days.
cosmo20btt is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 08:37 AM   #5
Copie
Yep +1 to a SR20DET, they have been put into pretty much every chassis known to mankind these days. They are cheap reliable and make good power, and they are light.
Copie is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 10:06 AM   #6
Fairlane
V8 Powaah
Fairlane's Avatar
Would not bother with a Ford 4 cylinder, their are cheaper alternatives. Vote 1 for NIssan SR20DET, Toyota 4A-GE or Nissan CA18DET. Personally I love the 4A-GE's, nothing like revving out to over 8k.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 10:08 AM   #7
chuckles
formerly lorosfalcon
chuckles's Avatar
2.3 turbo pinto out of a mustang?
03 BA XT I6
F6 CAI
3" intake pipe
XForce 2 1/2 exhaust with hidden tip
Battery in boot
Textralia clutuch
T56 conversion
King Springs SL front SSL rear
Pedders shocks
PBR upgrade front brakes
20" koya rush II wheels (street/show)
17" Enkei WRC Tarmac evo wheels (fun)
5% tint
Polk Audio 5x7 speakers
Option Audio 500WRMS amp
Clarion dual voice coil 15" sub in box
TO COME:
Typhoon engine conversion
chuckles is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 12:21 PM   #8
peachey80
Nothing stays standard !!
peachey80's Avatar
An RB30 is an in-line straight 6........... so that question of what is fords equivalent is easily answered : But I'm guessing you want an I4 ?
SHHHHHHH, Quiet, I'm hunting Lions !
Project Car : XA Coupe : XA Project
peachey80 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 01:14 PM   #9
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
SR20 is quite bulky, a very tight squeeze in a Mk1 Escort and I imagine a 59 Prefect/Escort van engine bay would be smaller again. I'd be starting by looking at a Toyota 4AGE or Ford/Mazda 4cyl from TX3 - or ideally an MX5, rwd already.
Old 28-01-2010, 02:45 PM   #10
PANELCORP
What ever you choose - just make sure it has a turbo
Will make up for all the lack of cubes you can imagine
I won't suggest a Turbo Rotary as that may scare a few too many people, but I would suggest the SR20DET with a nice little T04Z turbo hanging off the side
Will make more power and torque than you will know what to do with !!!
PANELCORP is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 02:50 PM   #11
LimeGlaze
LimeGlaze's Avatar
Yep, the Nissan SR20's are bulky, but they're cheap and easy to install when condisreing a RWD format. My other bent in life is toyota products, so consider:
4AG Series - 1.6L NA and factory supercharged units, becoming harder to find good cheap motors these days, as they are quite old now, lots of aftermarket support for them too. FWD and RWD format, but all the "good stuff" is FWD, so you'll need to convert to RWD
3S Series - 2.0L NA and factory turbocharged, can make outstanding power and are a good overall unit, lots of different evolutions of 3S out there, so do your homework before you purchase. FWD and RWD format and also East/West and North/South configurations. here's a pic of a Toyota Altezza 3SGE BEAMS Motor I installed into a 1977 Celica:
Anything Toyota produced later than the models listed above are still quite expensive, so probably not worth considering. There are also a gammit of 6 cylinder engines that will push your old tin around extremely effectively too!
LimeGlaze is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 03:08 PM   #12
Fev
Fev's Avatar
Very nice Celica! emails some pics to the Fast 4's guys when it's finished
Best bet for that lil Van would be either a 4AGE, CA18DET, Mazda BPT(TX3's etc) or a Pinto 2L which has been warmed over a little bit. These engines are all relatively the same size
The SR is phyically too big and it would be a huge amount of work to fit into the car.
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 03:10 PM   #13
302 XC
is it goin to be legally registered for road use ????
BEFORE choosing any motor i would consult relevant aurthorities as to wat u can or cant fit first
then on their recomendations work from there
to many people spend lotsa $$$$ to be told "no go"
then decide multi carb or efi ???
have seen 18rg twin cam toyota scream to 8,000 revs and pull 15 sec quarters in rt104 corona (no nos,no turbo,no water injection )just worked with twin carb
seems slow nowadays (was 15 odd years ago)but vn ss commodore owners around town (at the time )wouldnt try twice
how big is your wallet ???
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 10:44 PM   #14
banarcus
hmm eyebrows
banarcus's Avatar
Nissan motors in Fords.........sacrilege!
Then they'll cry when Ford start using a Ford V6 in a Falcon.....
