Old 21-03-2010, 05:11 PM   #1
Boza
Boza's Avatar
Default Bolt on's for v8
Hey guys i wanna give the unit a bit more poke i have a series 1 so the 185kw version i just wanna do some bolton's to make it a bit more responsive and ofcourse make it go a bit better.
I'm thinking underdrive pulley's, phenolic spacer etc..
While on the subject of the phenolic spacer what does it actually do for performance
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2010, 05:24 PM   #2
CFOUR
The Destroyer
CFOUR's Avatar
just get a blower. anything else is not really cost effective.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2010, 05:36 PM   #3
LUXO_8
windsor user
i realise you say you only want to do bolt ons, but, a cam would be the biggest net gain, followed by a good exhaust.
au motors had reasonable heads and intake so those 2 mods would really wake it up.
anything else would give a few kw here and there.....wouldnt really be that noticeable..
as mentioned, a blower would be the best course of action if you want to leave it untouched but increase power a great deal
Old 21-03-2010, 05:36 PM   #4
sd1800
Blower will cost about 6.5k for a raptor. That includes flash tuner, tune + labour. CAPA will be more expensive than that.
You can do alot of N/A work on a GT40P/Explorer motor for less than 6.5k and would net you the same results I would think?
OP, do the obvious first which is XR6T snorkel, high-flow filter(small gain I know), pacemaker(or difillipo if you can afford it) headers, high flow cats and dual 2.25" zaust'.
From here you need to open it up and you would want to put a warmish cam & 1.7 roller rockers + maybe small amount of porting work + custom tune and through a manual box you would be looking at
around 200rwkw. You may need to put AU 2/3 bluetop injectors in there for this figure. Yours are probably 19lb. Bluetops are 24lb.
Good luck.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2010, 05:41 PM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
Just the 3 basic mods for the cost effective budget that you can actually feel some sort of improvement IMO, some kind of Cold air intake with hiflo filter, decent cat back system, and a flash tune any more than that best you dig a bit deeper, Au Windsor is already underdriven . as for the spacer if you get it cheap give it a go ..
Originally Posted by Riksta
Old 21-03-2010, 09:23 PM   #6
JC
JC's Avatar
I have a 1/2" phenolic spacer in my garage - will sell & post to anyone for $30 inclusive. They are supposed to stop heat transfer between upper and lower manifold, and are probably more useful on an engine that generates lots of heat (ie blown/turbod) rather than an NA one.
Ford Performance Club ACT
Old 21-03-2010, 09:53 PM   #7
Windsor220
Now Fordless
Windsor220's Avatar
1/2" are too big for AUs I think. Causes fouling on the bonnet I've heard.
Old 21-03-2010, 09:55 PM   #8
Boza
Boza's Avatar
thanks for the info guys i'm gonna put one of those acron airboxes on and then i'll go and see my exhaust guy i was on ebay and a few mobs are selling pre made catback systems like redback,lukey etc.. are theese ok aor should i get my exhaust shop to make something up
