07-04-2010, 10:17 PM | #1 | ||
I've got a few quick questions, I've looked everywhere but couldn't find an answer, what diff do these run? I've found a Borg Warner LSD center on ebay, asked the seller without a response as yet so thought I'd jump on here, It's a 2 pinion 25 spline center, is that right?? Also is ~$170 a decent price for it?
07-04-2010, 10:20 PM | #2 | |||
You can't stop the signal
AU's run 28 spline axles, and the factory LSD's are 4 pinion.
Diff centers, open or LSD are borg warner units. Cheer
07-04-2010, 10:30 PM | #3 | ||
Cheers superroo, the bloke had it advertised to fit XE XF EA EB EF EL AU, always a good idea to double check hey
07-04-2010, 10:36 PM | #4 | ||
Just another mock-up..
are the centres interchangeable between live axle centres and IRS centres..?
cheers
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
07-04-2010, 11:17 PM | #5 | |||
I believe they are.
The only problem that i know of when swapping diff bits, occurs is when you try to put different ratio gears into a 3.08 housing. It is physically smaller i think Cheers
07-04-2010, 11:21 PM | #6 | ||
cheers mate....
08-04-2010, 12:04 AM | #7 | |||
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
08-04-2010, 12:21 AM | #8 | ||
great.... thanks mate..
08-04-2010, 05:39 AM | #9 | ||
That is true with the 3.08 housing, they are 75 series gears aka 7.5inch crownwheel with large 78 series pinion bearings, and a 78 series centre.
So you cant fit in 78 series 3.45's like i have found in mine, you have to put in 75 series gears and put the 78 series pinion bearings on it, and shim to suit. The pinion bearing is 150 thou too tight. |
08-04-2010, 11:07 AM | #10 | |||
08-04-2010, 01:13 PM | #11 | ||
EB2 onwards are, yes
08-04-2010, 01:15 PM | #12 | ||
awesome thanks mate
08-04-2010, 03:07 PM | #13 | |||
Resident AFF detailer
08-04-2010, 05:02 PM | #14 | ||
It means you can not fit ford 3.45's into it, you have to put in commodore 3.45's and swap the bearings over to the larger ford bearing. At which your better off just finding a 3.45 lsd out of a XR6/XR8 etc.
My car currently has 3.45 commodore gears in it, with the bearing change done, but im still looking for a 3.45 factory diff cause i dont expect them to last long. |
