Old 27-05-2010, 08:22 AM   #1
Erich
Default AU S3 6 - Spark Plugs
Guys
Have a June 02 S3 6 cylinder duel fuel sedan. What types of plugs do you recommend for gas?
FYI - I change the oil + filter every 10k & looking at the plugs at 20k?
Erich is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2010, 09:16 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
NGK BPR5EY
tree-fiddy each and they do the job excellently.
20k is too often (waste of money), 30k is fine.
Old 27-05-2010, 09:34 AM   #3
Erich
Originally Posted by Mr Hardware
NGK BPR5EY
TY
Had NGK BPR6EY's in them but will do the 5's
And gap - set to 0.9mm?
Old 27-05-2010, 10:43 AM   #4
Mr Hardware
Nah
i think you will have had BPR6EY-11's
the suffix indicates the gap in tenths of millimetres (ie 11 = 1.1mm)
a lack of suffix indicates the default gap of 0.8mm
which is juuuust right for LPG
Old 27-05-2010, 11:19 AM   #5
Mr Hardware
ah i've got it round the wrong way
BPR5EY-11's is what the petrols take
BPR6EY is what you want for gas
sorry mate
Old 27-05-2010, 11:56 AM   #6
Erich
kewl - so it had the correct ones in it (BPR6EY). Will replace with same then gap at 0.8mm and it should
