Old 03-06-2010, 03:37 PM   #1
ozzman1965
ozzman1965's Avatar
Default Engine Trouble light & dash dies
My daughters 2003 Focus intermittently has the Engine warning light come on, and the speedo, tach etc die but the car still runs.
Im hoping someone can tell me whats going on. Sounds like something is loose to me.
Assistance is apreciated.
Mark.
My XY resto: http://www.cardomain.com/ride/2338743
ozzman1965 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2010, 03:59 PM   #2
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
Any signs of hesitation of the engine when this happens? Like it's going to conk out, but stays alive?
Old 03-06-2010, 04:58 PM   #3
ozzman1965
ozzman1965's Avatar
Apparently not. Ive never seen it but she didnt describe the motor doing anything abnormal.
Old 03-06-2010, 05:19 PM   #4
DZFord
DZFord's Avatar
Sounds like the instrument cluster playing up. Common problem with the LR.
The LR owners will be able to tell you more about it.
Old 03-06-2010, 05:24 PM   #5
ozzman1965
ozzman1965's Avatar
Thanks. Unfortunately the car didnt come with an owners manual. Ive ordered a Workshop book.
Heres another issue. A/C doesnt get blown through the vents on fan speed 1 and 2. When you turn the fan to 3 or 4, the A/C turns off.
Old 04-06-2010, 02:05 PM   #6
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Mark, I agree with DZFord and it sounds as though it's an Instrument Cluster. They cost of bomb from Ford Dealers so if you are able to source one from a wrecker, that'd might be the better option.
Out of interest, how many km's has the car done?
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2010, 02:41 PM   #7
melbzetec
Old enough to know better
melbzetec's Avatar
Yep, sounds like the cluster. A fault cused by something called "dendrite growth" ....a crystalization that grows in the circuits causing them to "short" ( well something like that)
I searched and searched for months for a fix......but there is none and requires a replacement cluster. It will slowly get worse as time goes on.
New one is about $1200 from Ford. Try and find one from a wreckers that's close to your k's. (not easy)
I resisted for 18 months, but finally had to buy a new one.
(You may be able to get a German one through someone like Fordpartsuk.com, and it will be cheaper but you'll still need to get a Ford Dealer to reset the odometer for you)
Old 06-06-2010, 08:49 AM   #8
ozzman1965
ozzman1965's Avatar
Hi Ed. Its done around 125,000kms.
Old 06-06-2010, 08:52 AM   #9
ozzman1965
ozzman1965's Avatar
Well thanks heaps guys. I appreciate your feedback. Its helped heaps.
Regards, Mark
