Lost Boost Gained Class
guys im stuped
on the way home tonight the GF rings me and tells me my brake lights arnt working (she was behind me) but the funny things cruse control is working ...... but anyways i got home checked all the fuses and relays all seemd fine checked all brake light globes all are good Chaged the lights over the altaza ones to see 2 and still nothing is there a way to bridge the Brake light switch on the brake pettle to set the lights off?? so i can see if its that
2006 BF Fairmont Ghia
2001 AU Falcon Last edited by POELWYK; 04-08-2010 at 10:11 PM. |
Giddy up.
Is there a brake light switch up on the brake pedal stalk that might be sticking ??.
i just checked that its not stuck
2001 AU Falcon |
BA GT-P Owner
have a look at the earth wire there should be one in the boot
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
its not the earth the parkers work i checked anywyays and its def not that
2001 AU Falcon |
Formally kotevski22
Check if you're getting 12 volts at brake switch.
it was the switch i replaced it and thay worked so it was the switch...
thanks for the help guys
2001 AU Falcon |
