11-10-2010, 11:15 PM | #1 | ||
rexnet
broke my lock nut adapter. how to i get my lock nuts off?
3 suggestions ive had so far; 1. use a drive and hit the nut. this will loosen it and then you should be able to get it off with whats left of the adapter. 2. get a 1/2' drive socket thats to small and belt it on. ruining the socket but should get the lock nut off. 3.weld a bolt to the lock nut and this is possibly the easiest way to get it off. if you have access to a welder |
11-10-2010, 11:17 PM | #2 | ||
Belt on a smaller socket. Do it with an extension in place.
11-10-2010, 11:17 PM | #3 | |||
If you have an identifying number on the lock nut adapter you should be able to get another replacement one unless it is broken and still stuck on the nut.
Toy Car Build |
11-10-2010, 11:18 PM | #4 | ||
Size it up
Split 'em with a cold chisel or sacrifice 4 cheap sockets and rattle gun
edit: you run the risk of damaging the wheel with the chisel |
11-10-2010, 11:29 PM | #5 | |||
rexnet
11-10-2010, 11:31 PM | #6 | |||
Rhys
Toy Car Build |
11-10-2010, 11:40 PM | #7 | ||
You can buy replacements from Ford, I know this as a fact! Get your details and call your local Ford genuine spare parts! Look into doing that before you make any other attempt to remove them!
****el's drive Rotaries, Four in-line is a waste of time, Six in-a-row just won't go, If you really want something great, drive a great big Ford V8! God made Holden's to keep w*****'s out of Ford's, and yes I'd rather push my Ford than drive a Holden! |
12-10-2010, 12:07 AM | #8 | ||
i was gonna suggest drive it ford to get them to do it, but realised your car is in bits atm
12-10-2010, 01:33 AM | #9 | ||
cold chisel, or grind a slot in the end of the nut , big screw driver in the slot and loosen the nut, or find a big socket that is a tight fit over the lock nut, if you have clearance with the wheel, bang it on tight with a hammer(not to tight) , unscrew the nuts with a ratchet, put the socket in a vice use a big screw driver to knock the nut out of the socket ..........do it all again.
12-10-2010, 08:03 AM | #10 | |||
rexnet
12-10-2010, 06:50 PM | #11 | ||
Fixing Ford's **** ups
One single socket will do it. I have gotten numerous locknuts off for customers, using one single REPCO branded socket.
As for the cold chisel method. I'd seriously recommend leaving the cold chisel in the tool box.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
12-10-2010, 07:04 PM | #12 | ||
rexnet
Went to ford. They're ordering me one. $25 well spent
12-10-2010, 07:22 PM | #13 | ||
Giddy up.
That remind's me, I need to get one organised for mine aswell, thank's for reminding me.
12-10-2010, 08:39 PM | #14 | |||
12-10-2010, 08:45 PM | #15 | |||
Next upgraded Mk1 Leopard
UK
12-10-2010, 10:28 PM | #16 | ||||
Good to see you have it sorted
Daily: 2003 BA Fairmont Ghia - Mercury Silver | Sunroof | Tint | XR6T 3.46 LSD Project: 2001 AU II Fairmont Silhouette | Optioned 17" Tickford wheels + Sports suspension | Tint Weekender: 1989 NA II Fairlane - Rosewood | Standard (with functioning SLS!) Quote:
12-10-2010, 11:11 PM | #17 | ||
rexnet
contemplating getting a 2nd a some point in time hey.
13-10-2010, 03:06 PM | #18 | |||
I tend to view Tickford lock nuts as sacrificial items put there so the tyre fitters have someting to ***** up with their rattle guns - and to deter the honest theives............ Cheers James |
13-10-2010, 05:17 PM | #19 | |||
Giddy up.
13-10-2010, 05:37 PM | #20 | ||
Afterburner + skids =
Genuine Tickford lock nut removerer
13-10-2010, 07:21 PM | #21 | |||
rexnet
lol. well said |
13-10-2010, 08:56 PM | #22 | ||
Feel the boost
Well there is an easier way for all. Not sure where or how ya get them, but I have a set of NRMA supplied (i'm a mechanical tradie) lock nut removers. They are basically like a tube with threads that lock on to the nut, kinda the way an easy out does. If ya get the gist of it, very easy to remove the nuts and no damage to anything.
2005 BA Mk2 XR8 ...... Let the fun begin Drive carefully! Remember, it's not only a car that can be recalled by it's maker. |
16-10-2010, 10:25 PM | #23 | |||
17-10-2010, 02:55 AM | #24 | |||
Pro Street Au Ute
06-12-2021, 01:09 PM | #25 | ||
reviving an old thread. I have stripped my lock nut key. bad thing is they sit inside the wheel and can not put a socket over them to remove that way. Try'd welding the key to the nut but restricted as very tight area but kept snapping the welds as couldnt get much on, now ive burned off some of the chrome around the hole. Think the only way im getting it off is to remove the whole hub with the wheel on and drill out the stud from the inside. any one think of a different way. its on there tight. not happy Jan
06-12-2021, 01:18 PM | #26 | |||
06-12-2021, 01:41 PM | #27 | ||
The deep thinwall extractor sockets fit most situations.
An impact driver helps, also leave all other nuts on and fully tight. |
06-12-2021, 01:51 PM | #28 | ||
See https://fordforums.com.au/showthread.php?t=11487631 Though most of the links no longer work and the the irwin Bolt-Grip Link should now be: https://www.amazon.com.au/Irwin-Tool.../dp/B000QW6K8I and https://www.amazon.com.au/Tools-BOLT...id=2S0WG0RTYJ5 and https://www.amazon.com.au/IRWIN-HANS...t%2C388&sr=1-5 the ebay links https://www.ebay.com.au/itm/39370958...UAAOSwoblhl58~ and https://www.ebay.com.au/itm/40332439...oAAOSwZdthpEca The Supercheap link in my post there still works. While Bunnings don't list them on their website anymore some stores still seem to carry stock in there tool section and in any event as Irwin retailers they can get them in for you as a special order: any of these https://www.irwin.com/tools/trades/m...olt-extractors including https://www.irwin.com/tools/screw-bo...-specialty-set
regards Blue Last edited by aussiblue; 06-12-2021 at 02:07 PM. |
06-12-2021, 05:08 PM | #29 | |||
06-12-2021, 05:26 PM | #30 | ||
once i figure out how to post a pic i will put a couple up so you can see what im dealing with lol. wont be till the morning as just about to head to work
