Old 14-04-2011, 06:42 PM   #1
xd8you
xd8you's Avatar
Default Addicted performance, anyone used them?
I need to get my car dyno'd and was thinking of going to addicted performance in hallam. Has anyone used them and if so what did you think.
xd8you is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2011, 12:42 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default Re: Addicted performance, anyone used them?
If your just getting your car dyno'd then it don't really matter how good or bad they are.
If your getting your car dyno'd tuned then that is a different thing
Just google their name and see what results you get
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2011, 01:02 PM   #3
xd8you
xd8you's Avatar
Its a fresh motor so i need the tune done, carb re jetted etc.
Old 15-04-2011, 01:09 PM   #4
Sorted
Sorted's Avatar
Do Addicted Performance do carbs?
Most of the guys around are Fuel Injection Guros
Dynomotive in Bayswater - he knows carbs
Did my mate's 302 with twin 600's - they are really good with Triple Webers on Hemi 6's.
Casey Automotive in Cranbourne - i have seen some wicked Fords in his shop
Have you got a rev limiter as I dont trust any dyno tuner on a dyno without a rev limiter unless I am there during the tune
Tuned by DYNOMOTIVE
Old 15-04-2011, 03:28 PM   #5
xd8you
xd8you's Avatar
I dont know if they do carbs, but i assume they would, a capri getting around my way they did isnt injected.
A mate who has spent big big bucks with casey automotive told me to go to addicted???
Old 15-04-2011, 05:16 PM   #6
Fev
Fev's Avatar
Give them a call, ask you're local clubs etc
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2011, 09:31 PM   #7
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
try ace carbies in clayton.
yift is offline   Reply With Quote Multi-Quote with this Post
