Old 29-04-2011, 03:30 PM   #1
malazn mafia
Boss 335
malazn mafia's Avatar
Default How does car engine get factory installed in car
How does Ford install the falcon engine into a car on the assembly line? Is the engine pre-bolted onto the K-frame/steering/front suspension assembly, then the car body lowered onto it?
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2011, 03:48 PM   #2
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Default Re: How does car engine get factory installed in car
Thats basically it i think. The whole front suspension, engine and transmission go in from underneath as one unit.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2011, 03:53 PM   #3
malazn mafia
Boss 335
so is the quickest way to do an engine swap getting the whole front suspension/engine/transmission out of the donor car, wheeling it over to another car and then hoisting the car body down onto it? Why do people then use an engine crane?
Old 29-04-2011, 03:56 PM   #4
FPV GTHO
Engine cranes are cheaper than vehicle hoists.
Old 29-04-2011, 03:59 PM   #5
Woodsa
yeah, thats how the falcon/territory and most cars are done, I think the new commodore has removable front section of the body that goes on after the motor. But most just come up from beneath
Woodsa is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2011, 04:11 PM   #6
XB GS 351 Coupe
To remove the engine out of a B series Falcon, especially a V8, they put the car up on a hoist and lower the hole engine assembly down, have seen it done once at a Ford dealer.
Would hate to try and use an engine crane on a B series if F series Falcon, as there is no room, the engine is not designed and was never meant to come out the top of the engine bay unlike the older X series Falcons.
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2011, 04:47 PM   #7
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
i pull the engine out from the engine bay on the taxis. unbolt the trans, unbolt a/c and p/s pump remove radiator, undo harness from trans and computer, undo fuel lines and exhaust and its pretty much ready to come out. should take 2.5 hours max with an engine crane. all you will need is to have someone hold the bonnet back while you pull the engine out.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2011, 05:50 PM   #8
mik
mik's Avatar
http://www.youtube.com/watch?v=eUUEY...eature=related
Old 29-04-2011, 07:32 PM   #9
Papa Smurf
Papa Smurf's Avatar
When the V8's get changed where I work, that is what is done, removed from underneath.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2011, 09:06 PM   #10
ReVd_uP
ReVd_uP's Avatar
both motors can "easily" come out either way, top or bottom, just depends on available equipment, and working hands as to which way you decide to do it
ReVd_uP is offline   Reply With Quote Multi-Quote with this Post
