Old 05-06-2011, 08:27 PM   #1
robfg
Unhappy rear end squeak
can anyone help i have a fg xr6 c/c that has a squeak in the rear end the eye bushes have been replaced twice first with nolathane then with rubber the leaves have been packed with grease but still there is a squeak i'm sick of taking the car back and two days later its back has anyone had a similar problem
robfg is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2011, 10:15 PM   #2
mik
mik's Avatar
Default Re: rear end squeak
its funny how squeaks can sometimes be deceptive and come from somewhere else, dry rubber rubbing against something is good at making noise,ie, brake hose rubbing, clean dry heater hoses rubbing together,..........but if your sure its coming from the spring eyes maybe some rubber grease on the bushes or perhaps give it a drowning with silicon spray is all i can think of, give it a bounce after to see if its a goer, if its not them, also to check i`m thinking loose tray mount/s, cabin mounting? rubbing brake hose, loose exhaust mounting, good luck.
