Old 08-08-2011, 08:02 AM   #1
mel944
Default Engine changeover from 5 litre to 5.8 litre?
I need some help as I am trying to surprise my man by getting him things for his car, he has a 1995 EF XR8, 5 litre engine & would love nothing more than to be able to drop a 5.8 into her but is not sure if it would just bolt straight onto his existing EFI setup, please help me, I'm just trying to be a good Mrs!
mel944 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 08:18 AM   #2
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
Default Re: Engine changeover from 5 litre to 5.8 litre?
Where's the 5.8 coming from?
Chances are no it won't just bolt up and plug in and work. It would require a lot of work and then because (as far as I'm aware) the EF didn't come with any models offering a 5.8L, it would likely need to be engineered before it could be legally driven.
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 08:22 AM   #3
LTDHO
The one and only
LTDHO's Avatar
Simple answer is No.
I guess you meen a 351C?
I have seen 351W fitted but it's easier to stroke your 302 to 347.
Check out build threads of various e series cars, a couple are V8.
Mine I have stroked from 302 to 347.
Tuned by CVE Performance
Old 08-08-2011, 08:53 AM   #4
SSD-85
A factory 5.8L Windsor block can be sourced, but they are hard to come by. The easiest methods would be to, as said, put a stroker kit in. But if you do that youd want a stronger block than the 5L in it. So an aftermarket block would be the way to go. Either way, its not a cheap venture.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 09:15 AM   #5
mel944
Unhappy Re: Engine changeover from 5 litre to 5.8 litre?
Bugger..... So its not going to be an easy job? He did want to put a Windsor into it. I might have to stick to the other ideas you guys have given me about the stroker kit. I wouldn't have thought of that on my own, thanks guys!
Old 08-08-2011, 09:20 AM   #6
b2tf
not here much anymore
b2tf's Avatar
If it is an EF XR8 it is already a Windsor engine.
May I suggest you consider a supercharger kit - comes with everything you need and would make a great present. Matter of fact if he doesnt appreciate it (and you for giving it to him) I'll send you my address.
Something like this would be ideal:
http://www.raptorsc.com.au/kits.php?id=46
Cheaper than a stroker, less hassle to put together and if he doesnt like it or wants to sell the car down the track you can always unbolt it and sell it seperately.
2024 F150 XLT
Old 08-08-2011, 09:24 AM   #7
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Agree with b2tf.
Having said that, get a pro to fit it as well. Drive in, drive out all done and dusted.
Old 08-08-2011, 11:41 AM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
All the 5.0 EFI fits.. It has F series inlet ??
An aftermarket inlet is cheaper, use the lowest as bonnet clearance is tight ...
The heads injectors etc are same is 5.0
engine.. The F series EFI runs MAP ..
But can easily be converted..Here's an XE conversion..
http://www.fordmods.com/ford-v8-f2/3...ute-t9411.html
The front accessories brackets fit and sit alittle
wider than 5.0 engine..Longer serpentine belt..
The 351 block is much stronger ..
An aftermarket sump will be required if it has rear pan..
Daily driver GTE FG..
Old 08-08-2011, 12:47 PM   #9
a-total-tool
a-total-tool's Avatar
First issue - too tall for the EF/EL engine bay. TerroristGHIA on fordmods has recently completed the 351W into a EF fairmont...
http://www.fordmods.com/the-garage-f...65071-400.html
This page has pics of how far the motor hangs out of the bonnet. Keep in mind that the fairmont has a taller bonnet than the XR8 would, due to design..
A lot of the fittings have had to be customised (and the extractors also had to be built to match the application).
He has it in and running, he is currently getting the conversion engineered
a-total-tool is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 02:19 PM   #10
HULK EF
supercharger kit sounds the goods.. bolt in.. and bolt out for resale..
you sound like a top mrs!!!!! wish my mrs thought like you did!!!
HULK EF is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 02:29 PM   #11
mel944
Thanks but a super charger is going to cost us too much, do you think he would mind me doing this sort of thing for him behind his back? Got any other ideas for me?
Old 08-08-2011, 02:43 PM   #12
05_ENFORCER
05_ENFORCER's Avatar
OK, I'll bite.
What is your expected budget for his prezzy?
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 02:52 PM   #13
Yellow_Festiva
Where to next??
I think going from a 5 to a 5.8 would cost much more to be honest.
Old 08-08-2011, 03:01 PM   #14
mel944
I may be totally out of the loop because I have no idea how much this sort of thing would set me back, I was only hoping to spend $2,500 - $3,500 max, I'm not going to be able to do much for him for that sort of money am I?
Old 08-08-2011, 03:14 PM   #15
Yellow_Festiva
Where to next??
A turbo / supercharger conversion or the engine swap you wanted could not be had for that coin.
You can do some smaller bolt on mods such as intake, exhaust and tune for that money and get decent gains.
Old 08-08-2011, 03:25 PM   #16
mel944
Help me again, what can I get done to the intake system? I need to sound like I know what I'm talking about, because most mechanics see a chic coming & the price instantly doubles unless I have the knowledge to put them back in their place!
Old 08-08-2011, 03:35 PM   #17
b2tf
b2tf's Avatar
do you know if the car has had any work done on it already or is it all stock standard?
2024 F150 XLT
Old 08-08-2011, 03:47 PM   #18
mel944
I think its all stock standard, but on that note, he has had the heads done, but exactly what has been I don't know, the cat has been hollowed out, thats all that I know of.
Old 08-08-2011, 04:30 PM   #19
HULK EF
pacemaker extractors.. get a twin 2.5 inch cat back exhaust.. larger throttle body. lumpy camshaft..
SSHH.. no ones suppose to know about hollowed out cat.. RTA ESPECIALY!!!!! $$$ Massive fine$$$..
Old 08-08-2011, 05:48 PM   #20
StrokedXT
she should be able to get a second hand charger for that sort of budget
StrokedXT is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 06:09 PM   #21
Yellow_Festiva
Where to next??
If this is meant to be a surprise I also factored in fitting. A turbo will also require extra work in other areas (stopping, tune ect) I'm assuming if done properly???
Old 08-08-2011, 06:26 PM   #22
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
I think you might win wife of the year;)
Do you know the workshop that has done work previously on this car? You could always go to them and let them help you plan his surprise. I can't imagine they would rip you off if you tell them it's a present for your husband.
You could always look at a suspension upgrade instead of engine mods.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 07:01 PM   #23
mel944
Thats sweet about wife of the year, thanks heaps!
He got all the work done through mates of mates, what do you guys think of just getting the car converted to gas, getting him a mild cam & larger throttle body to suit the gas system? Would guys be happy with that?
Old 08-08-2011, 07:36 PM   #24
nb_351
building the xe...
nb_351's Avatar
i like most guys would be happy with any kind of improvement by the wife behind my back hahaha
go for a cam, intake and exhaust upgrade im sure for 3.5 k you could get new intake and everything...
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 08:52 PM   #25
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
With your budget i would do a inlet manifold, throttlebody and MAF upgrade, all this from a AU3 XR8 2nd hand can be brought for around $1000 off Ebay. Extractors and exhaust can be brought for $1500 fitted. All this stuff would be able to be used in the future should he want to stroke it or supercharge it. Allow $1000 to fit the manifold and tune after its all fitted. You would get heaps of power gain for $3500. To do bigger upgrades will cost $5000 and up as it needs so many extra's to fix the Standard EF XR8's poor exhaust and manifold. Even if you did a set of heads for $2500 you would still need all of the stuff i recommended on top. The exhaust and inlet manifold are the weakest link on the E series XR8 so start there. Just make up a gift voucher on your computer that gives him $3500 to spend on what ever he likes and put on it that you think he should do the above mentioned mods. That way he can shop around for parts on the forums here and Ebay to get the cheapest parts than pay a good workshop to fit and tune it, Hope the other guys on here think this is OK and hope this helps you, Shane
2015 FGX XR6 Turbo
Eaturbo is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2011, 07:42 AM   #26
mel944
Thanks so much for all that info, you seem to know what your talking about, thanks heaps, you have been extremely helpful!! Cheers!
Old 09-08-2011, 08:27 AM   #27
LTDHO
The one and only
LTDHO's Avatar
Gas?
Either GRA or gas injection.
Any other will make the previous mods a waste.
Old 09-08-2011, 08:38 AM   #28
mel944
Not on gas YET, hoping to get the conversion done just before the rest of the work gets done.
Old 09-08-2011, 12:05 PM   #29
SumoDog68
I d say get a Miele oven which can roast to perfection. Fits the budget perfectly. No trying to be sexist but best way to mens heart is through his tummy :-)
He ll be happy to have his car modding as his hobby and an outlet from (sorry) you :-)
SumoDog68 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2011, 12:33 PM   #30
spebgtsprint
spebgtsprint's Avatar
^^^^^ I think you are being sexist mate, Mel definitely sounds like a true car enthusiast lady, not some stereotype housewife...
Hey Mel, I do have a 5L supercharger system I am removing off my Sprint motor soon that is within your budget and will fit onto your hubby's motor.
PM me if you are interested. But no matter what which way you go, I would love to have an understanding car mad missus like you
"Ive spent all my money on fast cars, fast women and booze, the rest I've just blown"
XR8 SPRINT
FREE HO
MERC C55 AMG
AUDI A4
spebgtsprint is offline   Reply With Quote Multi-Quote with this Post
