Old 09-12-2011, 02:28 PM   #1
Evil Roy
Default Are Ford window regulators crap?
I've got an ED Fairmont, electric windows.
In May 2009 the front passenger side electric window regulator went, and I had it replaced using genuine Ford parts at a local garage (Holmac Auto, Nowra).
In May 2010, the regulator went again. I had it replaced under warranty but it still cost me $90 parts and labour from the same garage. I was ****ed off because it had barely been used.
In February 2011, the regulator went again. Again it was replaced under warranty but again it cost me $90 at the same garage. This time it had been used a little more, but not excessively.
Now, today, it has gone again. It got used once or twice a day during the warm weather but rarely during the winter. I made sure the window tracks were kept lubricated with dry lube and silicone spray, and in the winter made sure the mechanism was operated once a month in the winter.
I'm going back to Ford, and demanding that they replace it again, at no cost, and that they do it in their workshop at no cost to me.
Are Ford regulators garbage?
Am I being unreasonable with my demands?
(BTW - Yes, I kept all the receipts, etc)
Evil Roy is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 02:38 PM   #2
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Are Ford window regulators crap?
If it has failed that many times in close succession I would think there is some other issue causing this and that the regulators aren't the problem.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 02:44 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Are Ford window regulators crap?
Old 09-12-2011, 02:46 PM   #4
Peuty
Afterburner + skids =
Peuty's Avatar
Oo\===/oO
Old 09-12-2011, 02:48 PM   #5
Boss 330
miss my V8
Boss 330's Avatar
Boss 330 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 02:57 PM   #6
Bobman
Regulator
Bobman's Avatar
If you have a faulty switch, that can cause issues; ie being stuck when window going up, making it burn out the motor prematurely.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 03:03 PM   #7
Evil Roy
Should I see Holmac and get them to investigate? Or should I see Ford? Should any of this be a warranty claim?
Old 09-12-2011, 03:07 PM   #8
Evil Roy
Oh, and if it is a faulty switch (no evidence to suggest it is so far) should the garage have picked up on that?
Old 09-12-2011, 03:57 PM   #9
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
i have fixed a few E series Falcons that have had this same issue.
cars regularly, some yearly, having the same doors' window regulator fail.
it all starts off as the rubber/felt window runners in the door frame wear.
this causes the window to start to grab and pushes hard into the rubber,
9.9 times out of 10 it jambs on the way up.
people keep the button pressed on and try to force the window up.
spraying the window channel with silicon spray definately helps the glass slide on it but,
the rubber/felt has been fatigued/pressured by the glass that many times that something else starts to go too.
all this pressure makes the window regulators upright channel, where the glass is pushed/pulled from, twist where it is mounted near the top section of the door inner frame.
the inner door skin eventually twists too.
people just have the window reg replaced, and it happens again, sometimes sooner, sometimes later.
as the rubber/felt channel is still damaged from the original reg failing.
the top mount section of the inner door skin is also still twisted.
on some cars, it even twists the inner door frame down to below the inner door handle.
it is pretty hard to pick the twist in the frame, many people i have tried to show cant see it....
but if i show them where to watch, they can usually see the frame twist as the button get pressed and it starts to jamb.
people are suprised when they see the difference it makes after i have aligned the door frame
i repair the twisted inner door frame by loosening the top mount off, and i use the hook end of a crowbar to twist the frame back again.
it is a bit hard to explain the procedure, hope you understand what im trying to say though.
so if your window reg fails, it is not usually the window regs fault.
i recommend replacing the rubber/felt channel at the same time as a reg, and use some silicon to keep them lubed and operating smoothly/nicely.
cheers, and good luck,
craig
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 04:17 PM   #10
Fordman1
Fordman1's Avatar
Fordman1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 04:57 PM   #11
Evil Roy
So you think replacing the window runners might help?
(Sorry - this has turned into a Workshop thread!)
Old 09-12-2011, 06:27 PM   #12
drew`SEVNT5
Current
-2011 Nissan 370z Coupe (6M)-
-2006 Husqvarna SMRR450-
drew`SEVNT5 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 06:41 PM   #13
TheInterceptor
Cruising...
TheInterceptor's Avatar
Hahaha at all the identical posts...
Well Falcon windows jamming is a common thing.....my67xr is on the money though.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 07:10 PM   #14
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
C-C-C-C-COMBO BREAKER!
I'd check the voltage at the regulators with a multimeter, also:
Old 09-12-2011, 07:33 PM   #15
FPVGT500
FPVGT500's Avatar
It is a common problem for them to let go, my dads EF ones did and my BAs did too
FPVGT500 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2011, 10:37 PM   #16
davenl5l
davenl5l's Avatar
power windows use em or lose em.. also silicone lube helps on the runners
davenl5l is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2011, 11:49 PM   #17
fordman302
fordman302's Avatar
if your fuse kept blowing would you just keep replacing they fuse or look at what else might be causing the problems? mind you i do prefer the system in my fd over my au any day!!
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2011, 12:31 AM   #18
joolz
Basically its a dc motor and a lack of volts wont hurt it but as far as i know the E series have an overload breaker in them. They will restet after around 30 seconds. If it was a faulty switch you would notice it sticking going down if just pusling it and especially going up.
We all know as they are getting on in age now the E series have sticking windows as as already mentioned some lube does wonders.
Are we sure that aftermarket regulators werent fitted? As seeing the car is over 10 years old Ford do not have to supply OE parts anymore.
joolz is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2011, 11:27 AM   #19
HSVKILLA
moonlight rider
HSVKILLA's Avatar
HSVKILLA is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2011, 02:02 PM   #20
Evil Roy
The window channels appear clear, I kept them lubricated, and the pane slides freely in them.
I couldn't hear any hesitation or other unusual sound in the window when I used it; it operated smoothly and normally.
No blown fuses, no abnormal electrical problems (except a coolant low light which needed the coolant sensor cleaned, and the Smartlock module occasionally not letting the car start).
Old 17-12-2011, 08:53 AM   #21
Evil Roy
Had it replaced and the Ford guys said yes, they are crap.
I got them to inspect all the regulators I have had replaced, and the rear right door regulator - replaced about March this year - was correctly installed, has window runners in good condition, has no electrical faults.... and is about to fail because the regulator is 'bound up'. That window has been used maybe 10 times.
So yes, they are crap. I'm going to make them keep replacing them under warranty, and see what Ford head office can do about the situation.
Old 17-12-2011, 09:10 AM   #22
jrfttf
Getting By!?
jrfttf's Avatar
i know about 18 months ago a dud batch of regs went out, i saw some customers replace them a few times in as many months ect! Hopefully you haven't recieved the *** end of this batch!
jrfttf is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 09:26 AM   #23
Evil Roy
I think I did get those ones. Hopefully the latest one is okay!
The rear window one was non-genuine so I am going to have to replace it myself. Has anyone had experience with either Falcon Parts or a seller called Grant Walker Parts?
Old 17-12-2011, 10:14 AM   #24
falconnut
i bought some genuine ford parts off fordmods.com.au
Could try them, they where cheaper then all the local places.
2001 Falcon Fairmont AU2
Big turbo coming
Lsd
falconnut is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 10:16 PM   #25
jrfttf
Getting By!?
jrfttf's Avatar
grant walker gets a thumbs up off me!
Old 18-12-2011, 11:58 PM   #26
XR Martin
XR Martin's Avatar
The ones in my EL are original, sure you have to tilt the window by hand when raising it, but its still hanging in there.
I think you'll find its common amongst every car maker. Its lucky Ford ones arnt that expensive. Imagine an Audi or BMW one....
2004 BA wagon RTV project.
Old 19-12-2011, 08:10 AM   #27
Evil Roy
Aren't that expensive?!?
Ford genuine - $237 or thereabouts
Falconparts - $52
Both have a 12 month warranty. I'm going to risk the cheapy this time.
Old 19-12-2011, 10:01 AM   #28
Bearman
Moderator Ford Coupe Club
Bearman's Avatar
Too right. I had an ED Ghia which had the passenger front and both rear power window regulators fail. The only window working was the drivers one which was used all the time!!
Had to fix one of the rears as it was stuck in the down position. Got a55 raped on price too. Was yonks ago, cant remember exact details. So many problems. Got rid of it, an absolute sh!tbox.
Mitsubishi ASX Auto, White - Daily Commuter
XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote
http://www.fordcoupeclub.org
"If you don't know where you're going, any road will take you there" George Harrison 2001.
Bearman is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2011, 02:06 PM   #29
Evil Roy
I found it interesting that the left rear regulator (which Ford say is busted but was properly installed) was supplied by Ford parts, generic item and without warranty for about $110, basically busted immediately, and another generic from FalconParts costs $52 (plus delivery, about $12) and yet comes with a 12 month warranty.
This experience has really turned me off buying parts from Ford.
Old 21-08-2012, 08:42 PM   #30
Evil Roy
A bit of an update. The driver's window regulator has now gone. That one lasted about 18 months, used regularly, channels kept lubricated.... and another genuine regulator.
Never shopping Ford again; simply not worth it.
