Old 18-04-2012, 08:29 PM   #1
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Default Driving light mount/bar universal fit for any vehicle.
Has anybody used these before or something similar ?.
I am wondering how solid they would be with light's on them while driving, whether they would wobble ?.
Seem's like a cheap quick fix to add some driving light's to any vehicle and easy to take of ?.
http://www.ebay.com.au/itm/120830223...fvi%3D1&_rdc=1
Old 18-04-2012, 08:32 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Default Re: Driving light mount/bar universal fit for any vehicle.
If they are bolted to you bar reinforcement then they are fine.
Going on the AU?
You'll need some long bolts
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 08:40 PM   #3
BigCav
OzFalcon.com.au
BigCav's Avatar
just for future reference the aunger versions are obsolete and the current market replacement is the unibar
http://www.eagleproducts.com.au/pdf/...20Brochure.pdf
i used to sell the aunger version when the company was still around, can say that the units were pretty strong and i always had confidence in the product, but the wobbling etc would be more of a car problem so cant comment on that
ill be buying a set of unibars or maybe the aungers if theres more left soon enough
BigCav is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 08:50 PM   #4
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thank's guy's , I wasn't thinking of them for the AU at the start, more so for a SZ Territory, but a set on the AU for holidaying/night driving would be good, as they could be easily removed for normal day/town driving.
Old 18-04-2012, 08:55 PM   #5
T-Pak Addict
Jim
T-Pak Addict's Avatar
Pity your not in adelaide I have one sitting in the shed....
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 08:59 PM   #6
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Did you use it and if so what was it like.. did it wobble or was it solid when driving light's were on it and in use ?.
Old 18-04-2012, 09:17 PM   #7
Jim Goose
Touble is the plate on those bars is flat... and most bumper bars are curved!
I bought on for my AU and the gaps are so large where the screws go that big spacers are needed.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 09:20 PM   #8
Mechan1k
Mechan1k's Avatar
I got one and was going to use it with driving lights.
But decided on Larger driving lights ... 240mm diameter lights
The Unibar was inadequte for this.
I ended up with a nudge bar instead to bolt the lights to.
Old 19-04-2012, 06:58 AM   #9
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I've got one on my Focus, it comes down to how you mount it if it wobbles. Mine is held in by two nutserts drilled into the front crash support bar with two long M8 high tensile Allen headed bolts.
I've got two Hella rallye 4000 compacts on them and they don't bounce around.
Old 19-04-2012, 07:59 AM   #10
Smoke Pursuit
They don't work... Better off with a nudge bar.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 08:37 AM   #11
vanman_75
XD Sundowner
vanman_75's Avatar
Had 1 for my subaru , as above gotta mount em properly , and yes they are flat .
On rough roads it still bounced a bit , even with extra bracing ...got nudge bar on falcon ...much better .
It's in my shed also if ya want one cheap ..
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 09:28 AM   #12
Mont5.0
Mont5.0's Avatar
Worked fine for me. used all mounting holes and some decent screws/nuts/and oversized washers on the inside, the rounded front bar pulls up fine to the straight plate on the light bar. Very litle to NO vibration was had 'on road' any extra holes are then covered when the bar is removed and number plate re attached. Heres a pic with 2 x Cibie "oscars" on top of light bar.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 06:43 PM   #13
T-Pak Addict
Jim
only used it to mount a UHF antenna.. was fine for that
Old 19-04-2012, 07:38 PM   #14
Franco Cozzo
Thailand Specials
They do work, they just don't work when you just use self tappers.
http://img138.imageshack.us/img138/4...0610941076.jpg
They don't move.
Old 19-04-2012, 08:01 PM   #15
sneaky
sneaky's Avatar
i also say they work. had one on a mazda 323 astina and it was fine. i had smallish rectangle lights on it and it was fine, the lights would move a little bit but that could have been the car and bumpy crappy roads i was driving on.
i may even have the bracket floating in the shed if you are anywhere near central coast/newcastle nsw.
-tim
-Tim
sneaky is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 08:55 PM   #16
basteve
real aussies drive aussie
Police cars use those same bars so they must be good. The only problem is that most cars have a slight curve in the bumper bar and the driving light bar is dead strait and will not flex. You can compensate for this by using brass washers as spacers. That will secure tightly to your bar.
http://www.google.com.au/imgres?q=fo...,r:12,s:0,i:91
http://www.google.com.au/imgres?q=fo...:15,s:54,i:103
basteve is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2012, 12:49 AM   #17
smally289
growing up is optional
smally289's Avatar
Had one on my EF, mounted properly they don't wobble at all. Mine was secured onto the bumper reinforce using spacers to compensate for the slight curve.
Be warned, they attract locusts ..............
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2013, 01:45 PM   #18
captain
I have thought about this as the best way to secure the support bar, using nutserts.
However the plastic bumper is deep and difficult to get to fix the nutserts with the bumper attached. Can I still insert nutserts without first removing the whole bumper? Has anyone had similar experience., and share how they went about attaching the nutserts without removing the bumper or has instructions for removing the front bumper.
Thank you
captain is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2013, 02:53 PM   #19
mildxe
i mounted mine up a bit different to most
the bolts for the lightbar bolted through the bar reinforcement behind the number plate made my own holes in the lightbar and bar for this
and used nutserts on the number plate screws original holes all 4 of them
i can take it all off and return too normal with no holes to be seen
to take care of the curve in the bar i used stainless steel washers behind the lightbar also did the same for the number plate to space above the head of the bolts that hold the lightbar on so it did not bend the plate
with the nudgebar on you have to look close to see in there so you dont really see the plate spaced out
has been like this for over 12 months with no probs my hids mount too the nudgebar on a plate i made up so its quick and easy to remove wires plug in under the bonnet as i only use the lights when we travel to a friends place out in the middle of nowhere
fog lights stay on the car and have never noticed any wobble with them
mildxe is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2013, 03:02 PM   #20
revcore
revcore's Avatar
I have used the proper Uni-Bar driving light bar in the past and they do fit well and hold the lights nicely with very little vibration.
These days I prefer something a tad bigger on my ute...
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2013, 04:02 PM   #21
Franco Cozzo
Thailand Specials
That looks awesome.
Out of curiosity how much is a 5 poster worth? Thinking about getting one for my ambulance.
Old 15-09-2013, 04:29 PM   #22
revcore
revcore's Avatar
That looks awesome.
A good quality second hand 5 poster will set you back anything from $500 to $2000. I picked mine up second hand for $1000 including freight from Port Augusta SA.
My Ride...
Old 15-09-2013, 08:00 PM   #23
in_xcess
in_xcess's Avatar
Dito...
Number plate mount on the AU is tricky but for any car a nudge bar is better (but expensive). I plan to spray mine flat black to kill all that annoying chrome.
Daily drive: 2000 AUII Fairmont Ghia I6 75th Anniversary Edition in Sandstorm
In shed:1977 XC Falcon 500 250 Crossflow
in_xcess is offline   Reply With Quote Multi-Quote with this Post
