Old 06-07-2012, 08:53 PM   #1
tim_pato
tim_pato's Avatar
Default diff centre from au fairlane into au ute? yes or no?
As above, i have a 99 fairlane diff irs assembly and my ute needs a new diff centre, can i put the centre in my ute?
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2012, 08:55 PM   #2
tim_pato
tim_pato's Avatar
Default Re: diff centre from au fairlane into au ute? yes or no?
Or will i need to check stuff like axle spline count 1st?
Old 06-07-2012, 09:07 PM   #3
SSD-85
If its just a diff centre, then it should be a perfect fit. Just bear in mind the possibility of different ratios...
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2012, 09:32 PM   #4
tim_pato
tim_pato's Avatar
i did consider that, i was also wondering about the speedo censor, it wouldnt be as simple as swaping the censor would it? the censor would apply to the gear box aswell?
Old 06-07-2012, 09:33 PM   #5
tim_pato
tim_pato's Avatar
and would the axles be the same spline?
Old 06-07-2012, 09:46 PM   #6
SSD-85
The speedo sensor is located in the transmission, so if the ratios are identical then you could use the same one. if not, then use the one out of the cars ratio diff your putting in.
To the best of my knowledge, Ford didnt change spline spec for any model AU.
Old 06-07-2012, 09:56 PM   #7
tim_pato
tim_pato's Avatar
Sorry, i know where the speedo censor is located, what i was wondering...... is it just the diff ratio the censor works off? or will the gears running the censor be different in an auto box to a maual?
Old 06-07-2012, 10:04 PM   #8
SSD-85
The sensor works off the transmission alone, if you change the diff ratio, then it wont pick up the change. Unless you have a sensor to suit the new ratio.
I dont know where exactly the sensor is im sorry. Hopefully someone will post here with more info.
Old 06-07-2012, 10:13 PM   #9
tim_pato
tim_pato's Avatar
Sorry my friend but im confuse, if i chnge the diff centre and the speedo censor , will my speedo be accurate?, i have absolutley evrything out of a fairlane sedan.
Old 06-07-2012, 10:15 PM   #10
tim_pato
tim_pato's Avatar
By wich i mean i have not only the irs assembly but also the box and thus the censor
Old 06-07-2012, 10:17 PM   #11
tim_pato
tim_pato's Avatar
In any case it looks like im changeing the centre tomorrow
Old 06-07-2012, 10:17 PM   #12
tim_pato
tim_pato's Avatar
Thanks mate for your help
Old 07-07-2012, 09:07 PM   #13
tim_pato
tim_pato's Avatar
Well to answer your question, yes it fits. it's in.
Old 10-07-2013, 01:01 PM   #14
briggs8587
hey Tim...
Great forum to read, just bought myself a 2002 AU ute that drives awesome but diff is having a party back there...lol
Have found a 2nd hand low k's sedan diff and speed sensor to swap over.
Glad you did it first...
How have you found the sedan ratio in the ute?? Isnt it something like 3.15 instead of 3.45?
Thx again bud...
Stu (Perth)
briggs8587 is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2013, 02:46 PM   #15
madmelon
I'll just clear up the confusion here becuase the terminology being thrown around is obviously being used for different things.
A diff centre refers to the spider gears (and clutch packs in an LSD) and their housing that bolts to the ring gear. It may also refer to a spool, minispool or torsen mechanism.
Diff gears means the ring an pinion, less the centre described above.
Changing the centre doesn't change the ratio but may change the axle requirement if the splines are different. (Not on the AU)
Changing the diff gears may change the ratio and the speedo sender would then require changing as a result.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2013, 06:26 PM   #16
briggs8587
I hear ya MadMelon...
You are right with the terminology...
The question i had re the ratios is based on an assumption that Tim and just swapped the diff head over as a whole unit, not just swapped the centre over.
I will be popping the diff head out of the housing... popping in the sedan unit which i understand to have a higher gearing and changing speed sensor to suit.
With an obvious huge clean out and wash down of the axles to remove any lurking nasties.
Stu
Old 15-07-2013, 11:45 AM   #17
mik
mik's Avatar
how did you go with that old mate ??
