Old 03-08-2012, 08:14 PM   #1
Jay.Blanket
Jay.Blanket's Avatar
Default Little help? Au2 smartshield decided to die...
Whats the best process for fixing it.
I've had the car since brand new and I've tried both keys in it and both failed. What's the next step?
White TSHavoc
Go check it out at AUFALCON
http://aufalcon.com.au/jay.blanket
Jay.Blanket is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2012, 11:16 PM   #2
BHDOGS
Default Re: Little help? Au2 smartshield decided to die...
replacing the module id say thats what i had to do in my old ef i know its not smart shield but that fixed it
Old 04-08-2012, 10:59 AM   #3
irdonn
irdonn's Avatar
Jay.Blanket,
Can you elaborate on your Smartshield issue? What happens when you put the keys in the ignition and try to crank your car? What lights do you get on your dash?
Ian
06/01 AUII XR8
irdonn is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2012, 11:02 AM   #4
Kryton
Kryton's Avatar
if need be i have a matching module, ignition, key and door lock.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2012, 11:55 AM   #5
Jay.Blanket
car started ran for 2 seconds then stopped, tried to turn it over again it did the same thing and then i tried agian and now nothing. trying to turn the car over now the smartshield icon is rapily flashing...
White TSHavoc
Old 04-08-2012, 03:59 PM   #6
irdonn
irdonn's Avatar
The parameters between the BEM/ECU etc. might just need to be reset. Mine did this recently. Talk to your local auto sparky, most of them have the software to do it, or diagnose where the issue is.
Ian
06/01 AUII XR8
Old 10-08-2012, 12:06 PM   #7
Jay.Blanket
okay so i basicaly gave in after leaving my car at work friday night and coming back saturday morning to see if i could come up with anything or if sombody from NRMA could come get it started but instead they send an idiot who knew less then i did and tried less then i already had tried and i got it towed to blacklocks simply because they were the only place i could get the car into a shed for the weekend... soo i picked the car up monday and paid a ridiculous $320 and yes it starts... and has started fine all week......
Untill 20 mins ago.. drove the car about 5 mins stopped to pick somebody up the car was stopped for probably 5 minutes and jumped back in tried to start it it started and 2 seconds later died... tried again same thing.... 3rd times the charm and it started with a little extra help with me putting a few extra revs into it.... Also the car idle is really awful it tends to drop right down to about 500 rpm and then comes back up to about 800 but I dont understand why it is doing it... The car drives fine normaly its just the failed starts and the poor idle...
Whats causing all my problems???
is something in my car about to die??
Does anybody know where to start looking for the problem?
White TSHavoc
Old 10-08-2012, 02:11 PM   #8
rmack
rmack's Avatar
My 3 year old FG Xr8 just came back from being fixed. The car was spluttering and would not rev, it finally dies and would not fire up. They found a fuel filter full of black crap and a stuffed fuel pump.
Have the fuel filter/Pump been checked???
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2012, 02:22 PM   #9
13101093
13101093's Avatar
Hi mate i had the exact same problem with shart shield except for the rough running, it was the BEM (body electrics module) that was stuffed so a new one from the wreckers ($75) and needed to be reprogrammed to my car by auto sparky.
13101093 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2012, 11:10 AM   #10
CFOUR
The Destroyer
CFOUR's Avatar
as above, my bem died, a locksmith reparing it to the ecu workd short term but i ended up having to replace the bem, repco can order you 1, it has to be a match for youre car.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2012, 05:07 PM   #11
irdonn
irdonn's Avatar
Have you had the codes read mate?
Ian
06/01 AUII XR8
