Old 29-01-2013, 08:24 PM   #1
Caprobbo
Fordluva
Default AU Scanner
Hi all,got the Capri running and now I'm working on the DTC lights on the dash.Did anyone ever end up coming up with a scanner that handles the ford proprietary codes unique to the Au's?
Caprobbo is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2013, 09:48 AM   #2
rmack
rmack's Avatar
Default Re: AU Scanner
I have an AUII and I use Forscan and a cheap ELM327. Works Well.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2013, 10:30 AM   #3
Caprobbo
Fordluva
Yea I've got the same but can you actually clear faults on yours?.Some features are not enabled on mine.What can you do with yours?.Like I cant do a full system test,I only get a quick spin of the fans and a buzz from the fuel pump then get a error saying cannot carry out system test.Have you tried that test on yours?.Bret
Old 30-01-2013, 01:04 PM   #4
rmack
rmack's Avatar
I have used it to clear a Airbag fault.
As for the tests I think you need to carry out some manual tasks while it is in test mode.
KOER
Brake On/Off
Power Steering Pressure Switch
WOT
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 30-01-2013, 01:53 PM   #5
Caprobbo
Fordluva
Cool,Thanks for the info
Old 30-01-2013, 02:02 PM   #6
Caprobbo
Fordluva
While were at it you wouldn't know how to trick the crash computer into thinking that the pretensioners are still in place?. I'm using the Capri seats and have got the pretensioners off the au plugged in but I'm still getting error message "left & right pretensioners circuit open.Any ideas,I have to use the Capri seats to get it registered/engineered and have no lights flashing on the dash.
Old 30-01-2013, 05:39 PM   #7
rmack
rmack's Avatar
I don't know why they would say open circuit
Have you measured the pre-tensioners? I think they are around 2.2 - 2.8 Ohms
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 30-01-2013, 08:03 PM   #8
Caprobbo
Fordluva
Yea mines about the same I even tried a couple of 2.2 ohm resisters in place in the buckles but no go.I wonder if its something to do with the unused loom I cut out and terminated.
Old 22-07-2013, 11:01 PM   #9
Rugged73
Cheers 4 t nfo. Wots a wot test?
Rugged73 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2013, 11:04 PM   #10
Rugged73
I am still dubious if this will work... Have done heaps of research. AU is like the inbetweener OBD 1 CAN OBD (starwars phun) car. Proprietary designed link tc...
Old 22-07-2013, 11:07 PM   #11
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
Forscan works well.
New Beta version allows me to clear ABS Faults
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2013, 11:07 PM   #12
Rugged73
AU Fairmont. Sweet ride. Few gremlins... Lowk's... In need of diagnostic
