Old 29-06-2013, 03:39 AM   #1
trublu1
Default Ef 2 trans in AU1 Fairmont in limp mode
Hi,I recently replaced my auto trans from my 1998 AU1 Ford with a auto trans taken out of a Ef 2 Falcon.After we finished the swap i took the car for a test drive and i noticed that the transmission was in limp mode but then i would leave the car for several days drive the Ford again and the gears would change great then all of a sudden it would go into limp mode again. The person i purchased the trans from assures me that the transmission was in great working order and that i have no reason to disbelieve him. So with me putting the EF2 trans into my AU1 Fairmont shouldve ive changed something else like a computer,relay or something else?
trublu1 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2013, 07:07 AM   #2
dieseltrain79
Default Re: Ef 2 trans in AU1 Fairmont in limp mode
Different Ecu maybe ?
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2013, 09:01 AM   #3
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Welcome to AFF trublu1, it sounds like something electrical - inhibitor switch, speedo sensor? Hows the oil level, transmission not overheating?
Ring a couple of local transmission experts & let them know the problem, they will give you a few pointers & suggest to bring the car in for a ecu scan.
Heres a couple of links to look at -
http://www.fordforums.com.au/showthr...=101348&page=2
http://www.fordforums.com.au/showthread.php?t=11218637
http://www.fordforums.com.au/showthread.php?t=107640
cheers, Maka
Old 29-06-2013, 11:07 AM   #4
trublu1
cheers, Maka
Hi,trans fluid is clean and full,inhibitor switch is ok and speed sensor seems to be working well.Have contacted the experts to check out the trans next week,will wait and see.
Old 29-06-2013, 11:09 AM   #5
Maka
Maka's Avatar
No worries, good luck! Let us know how you go
cheers, Maka
Old 09-07-2013, 04:53 PM   #6
trublu1
Problem fixed,i just put in a new battery and the limp mode was gone!, Cheers.
