Old 05-07-2013, 10:46 AM   #1
And04133411
Default Au falcon verier gear adjustments
Hey guys! I'm having trouble dialing in my verier gear on my au falcon. I'm running a crows 2232549 stage 3 cam. I called up crows and they said to t.d.c to the rockers at a ratio of 1.8...... Which just made me even more confused :/ can any1 just tell me what degree to turn the verier gear to?
And04133411 is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2013, 04:48 PM   #2
dieseltrain79
Default Re: Au falcon verier gear adjustments
Really need a dial indicator to dial in the cam properly .
On my old 4l build , we found the cam was still almost 1.3 degree out . Lucky we dialled it in properly .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2013, 12:58 AM   #3
And04133411
So how would I go about that? Turn engine over till tdc at the harmonic balencer, loosen the verier gear and turn the cam till cylinder 1 inlet is exactly at its most open point (using dial indecator) and then tighten verier gear?
Old 06-07-2013, 05:39 PM   #4
dieseltrain79
Depends on the specs of the cam . If it needs to be dialled in at 2 deg advanced or the advance is ground onto the cam already .
Old 06-07-2013, 08:58 PM   #5
And04133411
Ok thankyou for ur help. Ill call up crows again and ask them if it needs to b set to tdc or to b advanced and wat to?
