Old 16-11-2013, 03:27 PM   #1
bartsau
bartsau's Avatar
Default Cruise control not working....not the normal problem!!
Well after the other week trying to install the aeropro steering wheel control loom and realising that it wasn't working probably because my steering wheel controls were not working...
I realised this as my cruise control wouldn't engage...
Since realising this I have checked all the brake lights, parkers and headlights.
My parkers were blown so have since changed them.
I changed the brake light switch to a known working one.
I have changed the grey screw in sensor/switch on the side of the brake master cylinder as my mechanic (An ex ford mechanic was saying this has in the past been a problem).
I have also checked all of the fuses and tried swapping all of the relays etc.
But I am still having no luck and I know it was working a couple of weeks ago so was wondering if anyone else has any ideas??
The car is a 2002 wagon, V8 and with a fairlane interior.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2013, 03:29 PM   #2
rayban76
AU3 5.0L Fairmont Wagon
rayban76's Avatar
Mate cruise could well be the clock spring ... That was my issue I had
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar
Ford Performance Club of ACT
[SIGPIC][/SIGPIC]
rayban76 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2013, 07:38 PM   #3
bartsau
bartsau's Avatar
Default Re: Cruise control not working....not the normal problem!!
Yeah that was the problem a while. Put another clock spring on and it fixed my horn, airbag light and cruise.
But seeing as my airbag light and horn wotk I didn't think it would be that.
Will try changing it again and see if that helps it at all? Fingers crossed...
Wagon Build
Toy Car Build
Old 16-11-2013, 07:40 PM   #4
rayban76
rayban76's Avatar
I know it took a long time between airbag/horn and cruise to all stop so hopefully that will fix it
[SIGPIC][/SIGPIC]
Old 16-11-2013, 08:17 PM   #5
Sox
RIP...
Sox's Avatar
Check the clutch pedal height.
Oval Everywhere...
Old 16-11-2013, 08:22 PM   #6
bartsau
bartsau's Avatar
Double post :/
Will do the clock spring tomorrow.
Hadn't thought about the clutch :/ will try that avenue too
Wagon Build
Toy Car Build
Old 18-11-2013, 08:02 AM   #7
bartsau
bartsau's Avatar
Well I now have cruise control working. Had missed it when checking but a pin had come out of a connector on the cable to allow the clutch to disengage cruise...
Still though can't get steering wheel controls for the stereo to work with this areopro wiring kit all plugged in??
Thanks for the tips guys
Wagon Build
Toy Car Build
Old 18-11-2013, 07:06 PM   #8
foxtrot3
foxtrot3's Avatar
Hi. Get in touch with Autobarn dandenong on 9792 5835, the new fitter there was the guru at aerpro. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
