Old 25-11-2013, 06:24 PM   #1
poppa smurf
poppa smurf's Avatar
Default one for the tilers....cutting glass mat tiles
Can glass tiles, as in splash back mats commonly used for kitchens, be cut using conventional methods (score and snap) or do I need a wet saw.
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2013, 06:49 PM   #2
Stefan
Stefan's Avatar
Default Re: one for the tilers....cutting glass mat tiles
Angle grinder with diamond blade cutter.
I'm a builder not a tiler so would still appreciate a tiler's response.
But most tilers I know are Korean...so might need to post this on Ssangyong forum .com.au
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2013, 06:55 PM   #3
Fpvboss335
Supercharged 335
I'm a tiler and yes you can cut it by scoring and snapping it with a sigma tile cutter or similar
You have to remember that you have to leaver the tile while trying to snap it
You don't hit it and crack it as it will shatter or break not straight
Also you need to use the right adhesive for glass tiles
335 Fpv GT in sunburst
Dynoed 479.3rwk
Lenso D1R 20in rims staggered rears with nitto invo rubber
K&N air filter
Xforce exhaust with Kpm gutted cats
Nizpro stage 2 input shaft(2nd one)
Herrod tailshaft
Kpm stage 2 intercooler with Herrod pump
1000cc Injectors
Kpm Twin 1000hp fuel pump
Herrod crank pulley
Yella Terra snout
Herrod fuel filter
E85 tune
Kristy my wife has an R Spec gt 2012 white number 311
Rear mufflers deleted
K&N filter
Fpvboss335 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2013, 07:02 PM   #4
Stefan
Stefan's Avatar
Good to know.
Judging by your sig I should start tiling too.
Old 25-11-2013, 07:16 PM   #5
poppa smurf
I have the large pro tile cutter, I've done a fair few floors, bathrooms and standard kitchen tile splash backs but wasn't sure about all the individual "brick" type tiles and how the little tungsten wheel would run over the gaps, never used these before.
what adhesive would you recommend, I will be purchasing all the gear from beaumont tiles.
Old 25-11-2013, 07:24 PM   #6
Fpvboss335
Supercharged 335
The tile cutter must be big enough to have the whole sheet laid flat so the mosaic doesn't move around while your scoring it
That's why I use the sigma tile cutter so the 300 x 300 sheet lays flat
I would try one sheet first and experiment
Can you post a photo of the mosaic and the tile cutter?
If it's only for a splash back I would use abamastic premixed adhesive
That way the adhesive will hold the tile up for you and it won't sag
Dynoed 479.3rwk
K&N air filter
Herrod tailshaft
1000cc Injectors
Herrod crank pulley
Yella Terra snout
Herrod fuel filter
E85 tune
K&N filter
Old 25-11-2013, 07:59 PM   #7
poppa smurf
The glass mosaic is yet to be chosen by the boss, I've only just installed the new stove and carcasses, bench top and tassie oak ordered (I'm making the raised panel doors) so choosing tiles are next, whether I can handle them will be a decision as to purchase.
My cutter can accept the 300 tiles easily (laid 300mm sq floor tiles for a friend not that long ago), I just wasn't sure about cutting these glass one's, never used them before.
I've made a note of the name of the adhesive so I can buy that at the same time, much appreciated.
