Old 12-02-2014, 07:14 PM   #1
garrathj
Default Mk1 Cortina clutch
I have a 1500 non crossflow cortina engine and gearbox in my car and the clutch is starting to make some strange sounds. I suspect it is the bearing as it only makes the noise when clutch is going in or out, it's fine while driving.
I've done some research and am not sure which way to go, it seems that you can use the Mk2 and later bearing with a spacer but i'm not sure if this is the best way.
Have any Mk1 Cortina owners (or others that have this clutch) had any experience with these?
I'll have the engine out soon so any help would be appreciated.
garrathj is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2014, 07:55 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Mk1 Cortina clutch
Hi. Not a lot of difference between any bearing, they all seem to last about the same amount of time as the clutch plate. Wait till you pull the engine and have a look at the rest of the clutch. If you cant get the right bearing see if the late bearing will fit with its carrier and no spacer. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2014, 08:18 PM   #3
garrathj
Thanks for the reply, really was hoping to preempt the problem and buy the correct part in advance so I could get the engine out and back in on a weekend.
I may have to take a punt and order in the original correct bearing and hope for the best!
The clutch has always worked fine, only the noise that has come up recently.
Old 13-02-2014, 07:37 AM   #4
hoodedaxeman
It depends which type of pressure plate you have, some need a bearing with a flat face, others need a bearing with a raised lip.
1965 Lotus Cortina
1963 GT Cortina
1962 Cortina Deluxe
1962 Cortina Deluxe
hoodedaxeman is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2014, 10:34 AM   #5
garrathj
Thanks, I'm hoping it is the standard one.
http://www.smallfordspares.co.uk/pro...ease-bearing-1
The engine/gearbox was put in the car in the 80s so I suspect it is more likely to be original type.
Old 13-02-2014, 04:37 PM   #6
Try Yesterford for the bearing.
Old 13-02-2014, 04:45 PM   #7
garrathj
Thanks, will give them a try!
Old 14-02-2014, 05:22 PM   #8
Dr Danger
Is it a daily driver?
Could you pull it out and take it down to your local bearing place and try to match it up?
Potentially easier than preempting what's in there. Just cause it was done in the 80's doesn't mean it's likely to be original. Perhaps the opposite...
Dr Danger is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2014, 07:11 PM   #9
garrathj
Yeah, have resigned myself to the fact I won't get out and in in one day so will pull apart and grab the right bits.
Yesterford seem to have everything so car will just have to be off the road for a week.
Old 16-02-2014, 09:55 PM   #10
allanv6gt
Tippy-tronic Free Zone
Better to take a week and get everything matching
than to
not get it right and have to take it all out again....bother !!!
Old 22-02-2014, 08:09 AM   #11
TER2BO
REV8380
TER2BO's Avatar
Hi, Garrathj how did it go?? have you pulled it out yet??
As has been posted you could have several different combos if it was last done in the 80's. The orginal combo was a 4bolt flywheel with coil spring pressure plate. Lots were changed to the later finger type with different bearings because they were better/stonger? or more plentiful? easier to repair?
If you are pulling it out suggest you have the whole lot check out/done.
Derry at BGT brakes in Dandenong had a GT500 and has been doing clutches/brakes for Cortinas since when he was in Hawthorn doing them for Harry Firth. Still does them for most of the Victorian Historic Cortinas running.
For Older Racing Drivers
2006 SY Turbo Territory - Dual Fuel, Debunged, F6 Lower Snorkel,Tune, 20"Rims and Pedders Suspension.
Previous Ford Rides
Tickford AU & SVO EA S/wagons - Dual Fuel
Mk1 & M2 Escorts - modified
1969 Mk2 GT Cortina - very orginal.
1964/5 Mk1 GT Cortinas Group N Racing
1965 Mk1 Lotus Cortina Group N Racing
1964/5 Ford Mustang Group N Racing
TER2BO is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2014, 08:52 AM   #12
garrathj
Thanks!
Engine is coming out today so it will all become apparent.
The engine has been modified quite a bit so it is entirely likely that the clutch was uprated a the same time.
I'll be taking some pics and determine what is actually in there and can go from there.
Old 23-02-2014, 12:50 PM   #13
garrathj
Well its all out and appears to be all Mk1 clutch components.
The thrust bearing seems to be ok and the plate and cover are in good shape. I'm suspecting it is the spigot bearing as it doesn't look so good and is a little worse for wear and given the sounds it was making it could well be that.
In any case I'll replace both bearings I think. Is there any trick to getting the spigot bearing out?
