Old 11-03-2014, 02:33 PM   #1
13101093
13101093's Avatar
Default Factory stereo mounting and ash tray light
Two questions someone may be able to help me with.
Does the factory double din stereo only mount using the side clips on the centre dash panel and the 'rod' thing at the back through a hole in the metal framing behind the dash??
the reason i ask is that i want to install an LTD centre dash panel however this sits the stereo lower so i would need to lower the hole that the rod goes through in the metal framing behind the dash.
Also since mucking around with the dash the ash tray light has stopped working. does anyone know if this is just always on?? i cant seem to find any sort of switch that would turn the light on when you open the ash tray.
13101093 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2014, 09:18 AM   #2
xr6tjet
[AUT-747]
xr6tjet's Avatar
Default Re: Factory stereo mounting and ash tray light
ash tray light turns on with the parkers. just pull the globe out with some pliers and fit a new one
xr6tjet is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2014, 09:15 PM   #3
b2tf
not here much anymore
b2tf's Avatar
There is a difference in shape between the 'low' series (what Forte/Futura/XR's had) dash area and the 'High' one (what Fairmonts, Fairlanes etc had). You wont get one to line up onto the other type of dash, you would have to change the whole lot.
2024 F150 XLT
