Old 05-05-2014, 01:31 PM   #1
FTe001
Default Au series 2 Xr6 vct, Air leaking ?
Hey All,
Friend of mine has a series 2 Au Xr6 Vct,
And when ever the car is running you can hear air leaking quite
Loudly also runs very sluggish since this air problem has started someone suggested replace the small plastic F piece under the throttle body done that and still no good its around under the throttle body area you can hear it,
Any help is greatly appreciated.
FTe001 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2014, 07:23 PM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default Re: Au series 2 Xr6 vct, Air leaking ?
My only suggestion would be to use about a meter of garden hose or similar with one end at your ear and the other end searching the engine bay to attempt to find the source of the noise. Search around all of the vacuum lines around the intake manifold and hopefully you will find the source of the leak.
Good luck with it.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 07-05-2014, 10:55 AM   #3
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Check & tighten your intake manifold bolts, you may find some loose?
cheers, Maka
Old 07-05-2014, 06:29 PM   #4
V8falcons
V8falcons's Avatar
cheers, Maka
yep,I agree,its also quiet common to suck the mani gasket in as well.
it will idle terribly as well....
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
