Young !@#$ Head
We wait for ever for it to start to rain up here in QLD and when it does i get in my XR8 and the passenger side front floor is wet. Is this a common thing or does anyone have any idea were the water may be coming from. I dont want to pull the dash out cause its a pain in th A$$ but i dont want my XR to rust from the inside out either!!
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
Wanting a sprint!
How is the seal in the front window top centre, as some off them have a small slice were they are joined.
Not to sure if it is common but my mate who had a au xr6 series 3 had the same problem before the window was replaced. I havent had it yet but i hope it dosent happen anytime soon and also hope you can source this problem before it causes other issues.
On track for mint turbo falcon |
#3 | |||
Back in black
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
Young !@#$ Head
the seal dosn't look like its sitting right so it might just be that. Cheers!!
The rubber seal on the AU XR ( not sure probably all models ) was prone to cracking and is common, you will find they let go with temp change, ie cool days then a hot spell or vice versa, due to a poor rubber used than did not take to the extreems.
I doubt warranty work would still be in with the AU ? but to get original seal back they will need to replace the wndscreen, otherwise they will use a crappy generic rubber across the top with silicone. |
Young !@#$ Head
yeah its been pretty cold up here at night time and no rain for months then all of a sudden this week has been like a cyclone and my car is like a flash flood!!! ill do the windscreen and hope thats it.
Hi mate, just wondering if you had any luck with the leak !as my au3 sr sedan has started to leak from under the dash next to the glove box when it rains heavy wetting the floor mat.The windscreen seals look all ok.I think the water is coming in from around the fire wall.Thanks Steve
Common as this is. I need mine done too.
