Old 17-05-2014, 06:34 PM   #1
Sox
RIP...
Sox's Avatar
Default Au vct ecu vs hp ecu
Evening kind people,
As some of you AU fans are aware, I'm building an AU XR6 VCT wagon.
So far, the body and interior is done, but I still need to do a head transplant.
The mechanical side is easy enough, and the electrical side also looks easy as it appears I only need to fit one extra wire to the ECU for the VCT solenoid.
So far so good.
Now, my question is this - I want to fit the VCT ECU now, before the VCT head is fitted.
Will this have any negative consequences in regard to ignition timing or fuel mapping due to having a cam which is stationary.
In other words, does a VCT ECU change the ignition timing and fuel map when the cam is advanced/retarded?
Or is it basically the same as a HP ECU, just with the VCT trigger?
Oval Everywhere...
Old 18-05-2014, 09:09 AM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: Au vct ecu vs hp ecu
I think your on your own Sox, you could try & find out for yourself but for me i would wait till the vct head is fitted just so nothing gets damaged ie: the ecu itself. Your call mate!
cheers, Maka
Old 18-05-2014, 09:21 AM   #3
Sox
RIP...
Sox's Avatar
I can't see how the ECU could be damaged simply by not having the VCT trigger connected.
But I think you're right as in it's a suck it and see thing for the ignition timing and fuel map.
Oval Everywhere...
Old 18-05-2014, 09:33 AM   #4
Maka
Maka's Avatar
I'm just being conservative Sox, nothing should get damaged but murphy's law may apply here lol!
cheers, Maka
Old 18-05-2014, 09:43 AM   #5
Sox
RIP...
Sox's Avatar
Fair enough, I know all about Murphy!
Oval Everywhere...
Old 20-05-2014, 04:05 PM   #6
Sox
RIP...
Sox's Avatar
In case someone else wants to do this, I have done it, with no adverse affects.
It feels identical to a XR HP ECU.
Oval Everywhere...
